ThosL Posted September 30, 2021 Share Posted September 30, 2021 I got a code on this. Since they said it is hard to get off at the junkyard, I assume it is tough to install, right? Link to comment Share on other sites More sharing options...
ThosL Posted September 30, 2021 Author Share Posted September 30, 2021 Code was P1443. Link to comment Share on other sites More sharing options...
heartless Posted September 30, 2021 Share Posted September 30, 2021 assuming you have inspections and need to fix this, correct? my 2002 has the same issue, but it does not affect drive-ability at all. I did buy the part from RA, but never put it in... one look at where it goes and I said nope, not dealing with it.. rust is the issue on mine. that solenoid sits on top of the charcoal canister, at the rear of the car, passenger side. even if rust were not an issue it is not exactly easy to get at. Link to comment Share on other sites More sharing options...
ThosL Posted September 30, 2021 Author Share Posted September 30, 2021 Exactly, a pain in the rump roast job, not sure what mechanics get for that. Beyond my ability. Link to comment Share on other sites More sharing options...
lmdew Posted September 30, 2021 Share Posted September 30, 2021 I've changed and pulled them from several 96-99 Legacy Outbacks. Rust free CO, easy as can be. I have not done one on a Forester. Link to comment Share on other sites More sharing options...
ThosL Posted October 1, 2021 Author Share Posted October 1, 2021 A good video on this job: Link to comment Share on other sites More sharing options...
ThosL Posted October 1, 2021 Author Share Posted October 1, 2021 (edited) The bolt was frozen, I tried a 12mm and 11mm--would not budge. So I wiggled it until it broke off the flange. I put the new unit in, the plug, the inlet and outlet hoses. Still have the CEL. I'll have to do a code check. How long if these are properly connected does it take to have the CEL go out? Do these need to be grounded? Edited October 1, 2021 by ThosL Link to comment Share on other sites More sharing options...
heartless Posted October 2, 2021 Share Posted October 2, 2021 clear the codes with a code reader.. not hard to do. drive the car a bit and see if anything pops back up. 1 Link to comment Share on other sites More sharing options...
ThosL Posted October 3, 2021 Author Share Posted October 3, 2021 Thanks so much. I pulled the cable off the battery which usually clears the codes, but it came up again. I checked the connections which looked OK to me. The previous unit was in rough shape. Is there any performance issue with these? Also saw the green connector under the engine to check solenoids, not sure if that would help. I'll go back to Auto Zone to check the code. I got 25% off at Advance Auto with an online coupon. Link to comment Share on other sites More sharing options...
ThosL Posted October 5, 2021 Author Share Posted October 5, 2021 I checked it out with a friend today; made sure the connection was good though a little loose. He commented on the connectors not being solid enough. Code was still up; is a continuity test indicated? Link to comment Share on other sites More sharing options...
ThosL Posted October 27, 2021 Author Share Posted October 27, 2021 That ended up being the issue; the plug was faulty on a continuity test. So went to two junkyards, in 2003 they changed the plug, fatter mating surfaces. So I found an 11/2001 Outback with a compatible plug and changed it which resolved the CEL code. 2 1 Link to comment Share on other sites More sharing options...
heartless Posted October 28, 2021 Share Posted October 28, 2021 Glad you got it sorted out and no, there is no real performance issue with that.. my 02 has had that code since I got it.. i did order a new solenoid, but never put it in, lol - the car runs and drives just fine and gets around 25-27mpg mixed driving - country roads & city - not much for freeway around me, lol Link to comment Share on other sites More sharing options...
ThosL Posted October 28, 2021 Author Share Posted October 28, 2021 You can't emissions around here without having that working. Unexpected plug failure, how often do these fail? How do they fail? A pollution device apparently. They changed those plugs in 2003, larger, probably as an upgrade. Link to comment Share on other sites More sharing options...
heartless Posted October 28, 2021 Share Posted October 28, 2021 the plugs for wiring rarely fail, but if it was changed, there was probably a very good reason for it. yes, the evap stuff is for pollution.. controlling the evaporation of the fuel. dont have emissions testing here.. not densely populated, so not as big of a deal here. But yeah, if you do have it, then stuff needs to work Link to comment Share on other sites More sharing options...
