brus brother Posted October 2, 2021 Share Posted October 2, 2021 Need to replace rotors for 2008 OB with 130K miles. Been using "lifetime" pads from Autozone and am led to believe they are aggressive on rotors. There is a lip of rust around the edges and no one seems to resurface rotors anymore? Any suggestions for mid price rotors? Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 2, 2021 Share Posted October 2, 2021 take a look at Centric brand. Quote Link to comment Share on other sites More sharing options...
heartless Posted October 3, 2021 Share Posted October 3, 2021 why do you think you need to replace the rotors? are they damaged? out of spec? warped? a small lip of crud around the outside is honestly quite normal.. as long as the braking surface of the rotor is in good condition, and within spec (thickness) there is no need to replace them. 1 Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 3, 2021 Share Posted October 3, 2021 There are shops that still surface rotors, just a little harder to find. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 3, 2021 Share Posted October 3, 2021 yeah, the minimum thickness is probably stameped on the rotor's edge or near the middle. Rule of thumb, if that 'lip'/'ridge' at the edge is 1 mm (think CD, 18ga wire, .040", or maybe dime thickness), on inside and outside, you are at the minimum. Quote Link to comment Share on other sites More sharing options...
brus brother Posted October 3, 2021 Author Share Posted October 3, 2021 2 hours ago, 1 Lucky Texan said: yeah, the minimum thickness is probably stameped on the rotor's edge or near the middle. Rule of thumb, if that 'lip'/'ridge' at the edge is 1 mm (think CD, 18ga wire, .040", or maybe dime thickness), on inside and outside, you are at the minimum. at least 1mm thanks for the reference Quote Link to comment Share on other sites More sharing options...
heartless Posted October 4, 2021 Share Posted October 4, 2021 15 hours ago, 1 Lucky Texan said: yeah, the minimum thickness is probably stamped on the rotor's edge or near the middle. Rule of thumb, if that 'lip'/'ridge' at the edge is 1 mm (think CD, 18ga wire, .040", or maybe dime thickness), on inside and outside, you are at the minimum. i don't know where you came up with this, but imho, it is nonsense. You may not have rust issues down there in TX, but in the northern climes, we do, and rust causes expansion of metal... I have had more than 1mm of "lip" on rotors but they were still well within spec. there is only one way to know thickness, and that is to measure, with the proper tools. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted October 4, 2021 Share Posted October 4, 2021 I always buy AutoZone pads, for the warranty. I've used a couple sets of the Duralast Gold rotors, which have a zinc-based coating. I found that to flake off very easily (it's designed to, as they coat the entire rotor and let the pads wear the coating off on the friction surface). Many of the standard Duralast rotors have a coating on them, now. I haven't tried them, but might be worth it. We buy a lot of O'reilly's Brake Best Select rotors at work, those have what looks like a nice coating on them. Just had a set installed on my mom's 2012 Impreza....I guess time will tell how they hold up. I bought a set of Durago coated rotors online several years ago for our Outback. I found that they left too much metal exposed for the friction surface, and I immediately began to get a ring of rust there, which crept under the coating. Aftermarket rotor prices seem to have doubled in the last couple years. Price out OE rotors for your application. They will be more, but they might be competitive, and they will be better. Quote Link to comment Share on other sites More sharing options...
brus brother Posted October 4, 2021 Author Share Posted October 4, 2021 2 hours ago, Numbchux said: I always buy AutoZone pads, for the warranty. Me too! For a while, I had a 2005 and a 2008 OB that used the same brake pads. "Lifetime warranty" takes on a whole new meaning 1 Quote Link to comment Share on other sites More sharing options...
ocei77 Posted October 8, 2021 Share Posted October 8, 2021 Generally the thickness is stamped on the inside of the rotor, IIRC it is 22mm. O. 1 Quote Link to comment Share on other sites More sharing options...
heartless Posted October 10, 2021 Share Posted October 10, 2021 On 10/7/2021 at 7:52 PM, ocei77 said: Generally the thickness is stamped on the inside of the rotor, IIRC it is 22mm. O. 22mm i believe is the minimum thickness... at least that is what the FSM says for my 2002 Forester, with similar specs for a 16" wheeled 2006 Outback... the 17" wheeled version has slightly larger specs, so I would suggest checking the FSM for your vehicle per the 2002 Forester FSM... Standard value - 24mm (0.945in) Service limit - 22mm (0.866in) 1 Quote Link to comment Share on other sites More sharing options...
