Njclark7 Posted October 15, 2021 Share Posted October 15, 2021 (edited) Hello, I've lurked often on this forum, reading advice and instructions on Subaru repairs and really appreciate the info. In my amateur ignorance, I was looking for advice on an engine swap for a 1999 Subaru Legacy Outback. I had an unfortunate incident in the middle of no where and my engine overheated busting a head gasket and it's simply cheaper and faster for me to drop a new engine in instead of getting into the gasket, re-machining it etc. I've been researching engines and I know this year of the Legacy Outback 1999 has I believe the EJ25 2.5L DOHC engine? I'm looking at replacing it with this:EJ202 2.0L SOHC engine, an EJ202 2.0L SOHC engine. Will this drop in fine? Will there be any hang-ups I need to be aware? I'm sourcing this out to my mechanic so before I commit financially and time-wise I want to make sure I'm making the right decision. Thank you kindly all you wiser and more experienced heads for your help! Edited October 15, 2021 by Njclark7 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 15, 2021 Share Posted October 15, 2021 Nope. That's not a compatible engine. You need to use the intake manifold from the 25D if you intend to use the 99 engine computer and wiring. You can install the 25D heads and manifold onto a 2000 to 2004 short block assembly - the compression will be higher but if you run premium it will be OK. GD Link to comment Share on other sites More sharing options...
lmdew Posted October 15, 2021 Share Posted October 15, 2021 I've been very happy with the 95 2.2 swaps I've done. www.car-part.com still shows some low mile engines. 96-98 2.2 will work but require a single port y pipe. Watch for EGR configuration for plug and play the 95 2.2 with matching ERG is great. Link to comment Share on other sites More sharing options...
Njclark7 Posted October 16, 2021 Author Share Posted October 16, 2021 Thank you guys for the feedback, much appreciated! Link to comment Share on other sites More sharing options...
