How to isolate front vs center diff
2012 legacy gt 6mt. Classic center diff failure symptoms. Mechanic says he "feels it in the front, so it's probably front differential and needs a new tranny". I'm skeptical. Is there a way to isolate whether the torque binding when warm is from the front diff or from the center diff, besides removing the driveshaft?
Edited by Charlie529
1 minute ago, el_freddo said:
It’ll be the centre diff unless you happen to have a VLSD up front and it happened to fail.
Replace centre diff, go from there I reckon.
Cheers
Bennie
Thanks Bennie, I'm likely to follow that advice. Forgive my ignorance, but how can I find out if I have a VLSD up front that could be causing the issue?
Legacy's never came with front VLSD. Yours doesn't have a rear VLSD either.  You'd have to jack the car up and look for signs of non OEM/Factory parts/work or spin the wheels and see what you get.
I answered you here as well:
Edited by idosubaru
4 minutes ago, idosubaru said:
Legacy's never came with front VLSD. This says your MT doesn't have a rear VLSD either:
http://www.cars101.com/subaru/legacy/legacy2012.html
That's great news. Thank you very much for clarifying that, and for your clear response on the other page as well. I'll hopefully update a positive outcome after replacing the VC/center diff.
