Help on 4eat 2000 Outback 2.5l trans compatibility
Hi i need to swap out the trans in my 2000 Subaru Outback 2.5l auto 4eat.  I need help to make sure what i buy is compatible.  Can any 00 01 02 03 04 outback used 4eat trans plug and play fit and electrically connect in my 00 outback?  Ive read that the gear ratios are the same across these years, but i dont know anything about the rest or electrical connections, harnesses, etc.  Please help.  I need to buy the right one.  I can be sure to get one only out of an outback so final drive would be the same.  Thx Paul
04 was a revision, and, from what I understand, the valve body changed, so it will not work correctly with the older TCU.
4-cyl and H6 have different gear ratios.
If you just punch in your car on car-part.com, it'll show you junkyard listings for compatible parts.
Yes the question is are the 2.5l 4 cyl 00 01 02 03 04 4eat outback transmissions compatible with 00.  You are saying 04 is not, so thats good info.  On car-part.com if i put in 00 it only shows 00 trans, not 01 02 03.  Thus my question here.  Its useless to help.
Yes the question is are the 2.5l 4 cyl 00 01 02 03 04 4eat outback transmissions compatible with 00.  You are saying 04 is not, so thats good info.  On car-part.com if i put in 00 it only shows 00 trans, not 01 02 03.  Thus my question here.  Its useless to help.  Can anyone confirm if 01 02 03 are compatible?
