gduerson Posted November 8, 2021 Share Posted November 8, 2021 I have a 2010 Subaru legacy. Recently I’m noticing a mouse squeak when my gears change it’s not every time but it’s becoming more frequent. It seems that it does not make the squeak when I shift manually the gears. My question is is my transmission going out or is this some sort of belt issue. It sounds like a belt would make a noise like what I’m hearing. Any help appreciated Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 8, 2021 Share Posted November 8, 2021 how old is the belt, how's it look, etc. Quote Link to comment Share on other sites More sharing options...
el_freddo Posted November 11, 2021 Share Posted November 11, 2021 I’m guessing it’s an auto. Could be a loose exhaust hanger bolt, broken engine or gearbox mount or a heat shroud that’s rubbing on something it shouldn’t be. Keep an ear out for it developing further and see if you can get a general location that it seems to be coming from Cheers Bennie Quote Link to comment Share on other sites More sharing options...
ebbsspeed Posted November 15, 2021 Share Posted November 15, 2021 U joints on propeller shaft starting to go? Quote Link to comment Share on other sites More sharing options...
gduerson Posted November 24, 2021 Author Share Posted November 24, 2021 First off. Thanks for advice. I do appreciate it. I’m a novice but the belts do seem to be fine. I’ll keep an ear on it and let folks know if I have any new information. Curious if it was the belt I’m hearing about a belt conditioner product? Would that be worth a try? Quote Link to comment Share on other sites More sharing options...
el_freddo Posted November 25, 2021 Share Posted November 25, 2021 Just put a bit of soapy water on the belts to make them quiet, or just rub a bar of soap on the belts, it’ll work it’s way around so don’t be stressed about having too much or not enough, can always add more if needed. Cheers Bennie 1 Quote Link to comment Share on other sites More sharing options...
