J41YD3D. Posted December 2, 2021 Share Posted December 2, 2021 Hi, I picked this rig up a few months ago and just figured out its "stuck" in 4wd. I pushed the button to disengage the 4wd only to be left with a motionless vehicle. If it's not in 4wd it doesn't move. I was hoping that it wasn't as serious as needing a whole new transmission but I've tired everything I could find on these old forums. I've tired going to the mechanism that activates the 4wd and that's actually about it. If theres anything, please help me! Thank you for your time! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 2, 2021 Share Posted December 2, 2021 broken axle? 1 Link to comment Share on other sites More sharing options...
el_freddo Posted December 2, 2021 Share Posted December 2, 2021 Could be a shot CV joint up front or a worn out front hub spline, allowing the cv shaft to spin in the hub. Or a front shaft may be removed for some reason with the hub held together with the remains of the outer joint with the stub axle piece. Cheers Bennie 1 1 Link to comment Share on other sites More sharing options...
DaveT Posted December 2, 2021 Share Posted December 2, 2021 It's not stuck in 4WD. It's lost it's default front wheel drive. Check the axles and hubs, to see if one is spinning without moving the wheel. Must be checked in 2WD mode, not 4WD. 1 Link to comment Share on other sites More sharing options...
J41YD3D. Posted December 4, 2021 Author Share Posted December 4, 2021 On 12/2/2021 at 5:21 PM, DaveT said: It's not stuck in 4WD. It's lost it's default front wheel drive. Check the axles and hubs, to see if one is spinning without moving the wheel. Must be checked in 2WD mode, not 4WD. Expand I was not aware that these vehicle were front wheel drive if not in 4WD. I'll make sure to check that out. Link to comment Share on other sites More sharing options...
