Always check and clean all of the grounds.
I have several sets of Red Subaru Injectors if you need them.
You can listen to the injectors, put a long screwdriver to the injector an to your ear while it running.  You should hear a crisp sharp ticking.
  • Like 1
Okay thanks. I will check the grounds. I can't imagine all injectors would go at the same time.
  • Like 1
