  On 12/5/2021 at 8:36 PM, 1 Lucky Texan said:
the little 'orifices' are usually adjustable. Sometimes a sewing needle is all that's necessay. Some designs may need something special, probably available foe a couplabucks at the parts store.
Expand
In the 08 the nozzle mechanism rides and pivots in a "sling" mounted beneath the hood. I think the needle technique applies to the type mounted on the hood.
If it's just one side, open the hood and make sure there isn't any leaf or other debris lodged in the mechanism keeping it from rotating freely.
Edited by brus brother
  • Like 1
no dirt impeding the movement within the "cradle" holding the sprayer?
I'm assuming it is just one side that is wonky?
Compare the mechanisms and movement within the cradle to the other side.
Did it pop out of the hinged position or is the hinge broken?
This ain't rocket surgery ;-)
