ThosL Posted December 7, 2021 Share Posted December 7, 2021 https://www.youtube.com/watch?v=1NteheE_cO4 This is a fairly lucid video on changing the inner tied rod end, but there were a number of aspects of the job that scare me that make the job beyond my tool and aptitude level. What is the book time on doing this job for professionals? I went to a mechanic today after getting the tie rod end tool at Auto Zone who has done some excellent work for me in the past but he is too busy, doesn't charge enough. I'll try to check in with another mechanic on the job. Link to comment Share on other sites More sharing options...
Liftedlego96 Posted December 7, 2021 Share Posted December 7, 2021 Dont be scared! Dive rite in. Its probably not as hard as you think. Im not sure how long it takes a machanic but me myself in the garage taking my time mabey 2 hours. The trickier part is the alignment. Not hard just abit tricky if its your first go at it. Link to comment Share on other sites More sharing options...
idosubaru Posted December 8, 2021 Share Posted December 8, 2021 3 hours ago, ThosL said: https://www.youtube.com/watch?v=1NteheE_cO4 This is a fairly lucid video on changing the inner tied rod end, but there were a number of aspects of the job that scare me that make the job beyond my tool and aptitude level. What is the book time on doing this job for professionals? I went to a mechanic today after getting the tie rod end tool at Auto Zone who has done some excellent work for me in the past but he is too busy, doesn't charge enough. I'll try to check in with another mechanic on the job. 1 hour labor, 1 hour alignment. It's really easy but the press fit end getting stuck and lock nut and removing it without a special tool (or buying/renting the tool) can be troubling if you're not well experienced with tight fasteners. I can't see yours but that lock nut and the end joint press fit - can be crusty rusty in the northeast and cause a bit of a wrestling match without good tools and torch. I'd inspect the rack boot really well first or have a new steering rack boot on hand just in case - removing a quarter century old boot might render it unusable to reinstall. That's the most dangerous part on the entire vehicle, I'd use Subaru only for tie rods. I would quite literally install a used Subaru OEM before an aftermarket. If you get a Subaru one too it's probably easier to ensure alignment is the same by counting turns...assuming the parts are the same/equivalents. I've replaced subaru inner tie rods without removing the outer tie rod. Loosen the lock nut, turn the inner tie rod out so it comes out of the outer tie rod (thereby skipping the need to remove it). Remove boot. Use inner tie rod tool to swap tie rods. Literally don't have to remover any bolts or nuts - just the boot and tie rod itself. Count the number of turns of the tie rod and install the new one to the same depth. 2 1 Link to comment Share on other sites More sharing options...
ThosL Posted December 8, 2021 Author Share Posted December 8, 2021 I have the part; will check with Frank at the shop, who is the manager to see how much he'd charge for the job. I had the alignment done, free re alignment within 60 days; they flagged that part. Link to comment Share on other sites More sharing options...
lmdew Posted December 8, 2021 Share Posted December 8, 2021 1+ Loosen the lock nut, turn the inner tie rod out so it comes out of the outer tie rod (thereby skipping the need to remove it). Remove boot. Use inner tie rod tool to swap tie rods. Literally don't have to remover any bolts or nuts - just the boot and tie rod itself. Count the number of turns of the tie rod and install the new one to the same depth. I center punch the nut and outer tie rod. Loosen the nut and then do as above. Once it's out, before I move the nut I take a bit of safety wire and measure from the nut to the end of the tie rod, bend it 90 degrees over the end of the tie rod. Now you have a tool to put the nut on the new tie rod where it needs to be. Once it's all back together and you have driven it a bit do a quick alignment check. Take some mason's line and tie it to the rear sway bar bolt. Wrap the line around the outside of all 4 tires about 6" off the ground - as high as possible without hitting the body. Tie the line off tight on the opposite side of the sway bar. With the toe set you should have about a 1/8" gap at the rear of the front tires. Now take it and get a 4 wheel alignment! I've gotten very close with the string. Link to comment Share on other sites More sharing options...
ThosL Posted December 8, 2021 Author Share Posted December 8, 2021 I went to the mechanic who had the tools today; a lift in a heated facility, a vice, cut off tool etc. which I don't have. A picture of the separated inner tie rod end: Link to comment Share on other sites More sharing options...
ThosL Posted December 8, 2021 Author Share Posted December 8, 2021 The tire alignment facility could not get the bolt to turn to accurately adjust alignment. The nice black mechanic was able to do the bare basics; but the front alignment was so far off when he was done that the car was really not drivable. I went back and when a bay opened up after an hour or two wait he was able to get it closer so the car could be driven. I'm looking forward to getting the alignment done tomorrow. I paid $150 for the job. Link to comment Share on other sites More sharing options...
lmdew Posted December 9, 2021 Share Posted December 9, 2021 Threads look bad. How's the outer Link? Link to comment Share on other sites More sharing options...
ThosL Posted December 9, 2021 Author Share Posted December 9, 2021 (edited) Nut would not turn, so the alignment facility tagged it as needing replacement; other threads on unit were probably further damaged when mechanic put it in vice to separate inner from outer which he had trouble doing. He put in the Moog unit I got. Mechanic did not know how to approximate alignment, vehicle was not really drivable when I left the shop and had to come back. Edited December 9, 2021 by ThosL Link to comment Share on other sites More sharing options...
idosubaru Posted December 9, 2021 Share Posted December 9, 2021 (edited) 3 hours ago, ThosL said: Nut would not turn, so the alignment facility tagged it as needing replacement; other threads on unit were probably further damaged when mechanic put it in vice to separate inner from outer which he had trouble doing. He put in the Moog unit I got. Mechanic did not know how to approximate alignment, vehicle was not really drivable when I left the shop and had to come back. Glad they got it done, too bad on alignment but at least that's a little more straight forward and should go smoothly minus the time, schedule, waiting, etc. Torch - that nut comes off in 15 seconds. It wasn't a Subaru part so couldn't retain alignment anyway, that was your choice. Aftermarket dimensions can vary and can't be expected to retain alignment. Imdew and myself both described how it's done before the car went to the shop. Take them a Subaru part and explain to them what we told you or just read/show them the very easy/normal/typical directions we wrote. They'd be glad to learn a new skill. We try to help.... On 12/7/2021 at 9:46 PM, idosubaru said: If you get a Subaru one too it's probably easier to ensure alignment is the same If the shop doesn't know how to retain alignment on a tie rod swap then you may want to avoid them for future suspension work (and more). If they don't have a torch and can't retain alignment they sound very limited for a northeast subaru shop. Edited December 9, 2021 by idosubaru 1 Link to comment Share on other sites More sharing options...
ThosL Posted December 9, 2021 Author Share Posted December 9, 2021 I'll ask them why they don't use torches; Town Fair tire, generally good. Is the Moog not a good brand for the front end parts? Link to comment Share on other sites More sharing options...
Numbchux Posted December 9, 2021 Share Posted December 9, 2021 Moog is just another sticker on Federal Mogul parts. Suspension companies buy and sell from different suppliers. Some are better, some are not. But there's no consistency. Link to comment Share on other sites More sharing options...
ThosL Posted December 9, 2021 Author Share Posted December 9, 2021 Before and after on alignment: Last time: https://i.imgur.com/UH27Cgk.jpg Today, different shop: https://i.imgur.com/WJkLK8y.jpg Link to comment Share on other sites More sharing options...
Lightning Racer Posted December 10, 2021 Share Posted December 10, 2021 (edited) 14 hours ago, ThosL said: Is the Moog not a good brand for the front end parts? It's bad from my limited experience of one Moog part (one for one bad is 100% bad for me). I put a Moog front lower control arm into my dad's 2005 Outback, and immediately noticed that the camber was way off with the camber bolt in the same position. It couldn't be corrected to even close with the stock camber bolt. The lateral dimension of the part must have been way off. Here's a mechanic's long term experience with Moog parts: Edited December 10, 2021 by Lightning Racer 1 Link to comment Share on other sites More sharing options...
ThosL Posted December 10, 2021 Author Share Posted December 10, 2021 Rock Auto has a very efficient search algorithm. Only Moog, Mevotech and AC Delco for part providers. https://www.rockauto.com/en/catalog/subaru,2002,forester,2.5l+h4,1378739,steering,tie+rod+end,7428 You are going to have a few lemons with every car parts provider. If you get them from Subaru, you will probably pay 2-3 times as much. Link to comment Share on other sites More sharing options...
Numbchux Posted December 10, 2021 Share Posted December 10, 2021 48 minutes ago, ThosL said: Rock Auto has a very efficient search algorithm. Only Moog, Mevotech and AC Delco for part providers. https://www.rockauto.com/en/catalog/subaru,2002,forester,2.5l+h4,1378739,steering,tie+rod+end,7428 You are going to have a few lemons with every car parts provider. If you get them from Subaru, you will probably pay 2-3 times as much. That Moog one is $22+shipping OEM is $35+shipping https://www.subarupartsdeal.com/parts/subaru-tie-rod-complete-gear-box~34140fc000.html 10 times the quality, for less than twice the price. Link to comment Share on other sites More sharing options...
Lightning Racer Posted December 11, 2021 Share Posted December 11, 2021 12 hours ago, ThosL said: Rock Auto has a very efficient search algorithm. Only Moog, Mevotech and AC Delco for part providers. https://www.rockauto.com/en/catalog/subaru,2002,forester,2.5l+h4,1378739,steering,tie+rod+end,7428 You are going to have a few lemons with every car parts provider. If you get them from Subaru, you will probably pay 2-3 times as much. 2-3 times as much would have been worth it for me, especially seeing that video later and realizing that it's a common thing with Moog parts. Spent more than that messing around, getting it aligned twice with a weaker camber modifying camber bolt (wouldn't have needed an alignment at all with a good part). I should have just taken it off and thrown it in the bin and gotten the Subaru part. In fact, I might still do that at some point next time I visit my folks, just to do it right. Link to comment Share on other sites More sharing options...
ThosL Posted December 11, 2021 Author Share Posted December 11, 2021 If you want it perfect, you're going to have to replace all the "substandard" parts which will keep you busy for a long, long time. Ball joints, make sure they are all OE and in good shape for the duration; all tie rod ends etc.. Not worth my trouble and if I had known that the nut could have been turned with a torch, would have done it myself and saved all the pain and aggravation. Link to comment Share on other sites More sharing options...
asternay Posted June 7 Share Posted June 7 (edited) On 12/8/2021 at 1:42 AM, Liftedlego96 said: Dont be scared! Dive rite in. Its probably not as hard as you think. Im not sure how long it takes a machanic but me myself in the garage taking my time mabey 2 hours. The trickier part is the alignment. Not hard just abit tricky if its your first go at it. When it comes to Attract Mode list tips and tricks, I've got a few gems up my sleeve! One of the most effective strategies is to focus on creating eye-catching headlines and thumbnails that draw viewers in from the get-go. Additionally, optimizing your keywords and tags can help improve your video's visibility and attract more viewers. And don't forget the power of engagement—responding to comments and interacting with your audience can help foster a sense of community and keep viewers coming back for more. Speaking of tips, if you're a college student looking for expert assistance with your papers, I highly recommend checking out https://essaypro.com/buy-college-papers. They offer top-notch academic writing services tailored to your needs. Thanks for the information! Edited June 7 by asternay Link to comment Share on other sites More sharing options...
