tylertrend Posted December 11, 2021 Share Posted December 11, 2021 My recently purchased '99 SUS is making some very loud squealing noises from the front left area. It's a rotational noise and changes pitch with vehicle speed but is VERY pronounced at slow speed. Several weeks ago it only really did it when turning but now it's pretty much doing it all the time but worse when turning. Powering hard through low speed turns helps quiet it down but it never goes away entirely. I recently performed a full front brake job with new rotors, pads and calipers on both sides; needed done badly anyways but no change. Everything else in the front end appears pretty tight. The vehicle only has 50k miles and it handles like it. CV's appear fine, struts aren't broken or rubbing on the body. Kinda at a loss right now and I don't have a workspace currently to perform any diagnostics. I've seen other threads that mention the possibility of wheel bearings with this issue but I've never heard a bearing make this sort of noise firsthand. The RIGHT side wheel bearing has a very small amount of play but the LEFT side is completely tight. RIGHT side doesn't seem to make any noise. Any advice is appreciated. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 11, 2021 Share Posted December 11, 2021 no sign of a spot on the brake shield rubbing on the rotor? I suppose you could try loosening/re-torquing the axle nut. maybe a previous owner torqued it while on the ground. FSM says it needs to be in the air/no weight on it. (yeah, it's a real stretch, but also easy to try ....) Link to comment Share on other sites More sharing options...
tylertrend Posted December 11, 2021 Author Share Posted December 11, 2021 I'll look into the axle torque. Definitely no part of the braking system has anything to do with it. Link to comment Share on other sites More sharing options...
tylertrend Posted December 30, 2021 Author Share Posted December 30, 2021 Noise ended up being a front wheel bearing. Pricey repair but it's all good now. 1 Link to comment Share on other sites More sharing options...
heartless Posted December 31, 2021 Share Posted December 31, 2021 thanks for coming back and updating. and yeah. wheel bearing jobs are not cheap, but unless you have the space, time, and access to the right tools, you are better off having it done Link to comment Share on other sites More sharing options...
