Liftedlego96 Posted December 13, 2021 Share Posted December 13, 2021 Does anyone have experience with sway bar upgrades? Ive read abit about white line sway bars and brackets. Not sure if its worth the money though. I would definitely like more stability but the difference would need to be fairly dramatic for me to dish out the cash for the sway bars plus bushings and brackets. Mabey i should just replace the old ones with oem parts? The links and brackets im running rite now are pretty worn out looking. Not sure if stock parts will give me the difference im looking for. Link to comment Share on other sites More sharing options...
ronemus Posted December 13, 2021 Share Posted December 13, 2021 (edited) Upgraded sways do make a difference, but they should be paired with upgraded shocks/struts (Subarus are underdamped in stock form). I have Whiteline 24 mm front and 22 mm rear bars on my '17 Outback, along with Rallitek overload springs in the rear, and Bilstein B4 struts in front and B6 shocks in the rear. That setup in combination with a custom alignment (0* toe and -0.5 * camber at all 4 corners - Moog adjustable rear lower and front arms needed) leaves just a bit of understeer. I also use Enkei Raijin 19" wheels and Continental DWS 06 tires in 245/50-R19; the tire/wheel upgrade has the biggest effect, but all of the other components have a noticeable effect. Edited December 13, 2021 by ronemus Link to comment Share on other sites More sharing options...
laegion Posted December 13, 2021 Share Posted December 13, 2021 Probably don't want to hear this...but as much as you've lifted your car; it will make it difficult to regain that stability. I did not have this issue at all with my '95 with Outback struts. Link to comment Share on other sites More sharing options...
Liftedlego96 Posted December 13, 2021 Author Share Posted December 13, 2021 Thanks for the info. I think ill just go with oem parts and get what i get. I dont expect my handleing to go back to where is was before the lift but something is better then nothing. Ill just be disconnecting the sway bar when offroading anyway. No sence in upgrading when ill only use it half the time ha 1 Link to comment Share on other sites More sharing options...
laegion Posted December 15, 2021 Share Posted December 15, 2021 On 12/13/2021 at 12:11 AM, Liftedlego96 said: Thanks for the info. I think ill just go with oem parts and get what i get. I dont expect my handleing to go back to where is was before the lift but something is better then nothing. Ill just be disconnecting the sway bar when offroading anyway. No sence in upgrading when ill only use it half the time ha How deep of snow are you planning to drive in? I have been in 2ft of snow in my '95 easily with just the outback struts and outback sized tires. I've only ever gotten stuck in packed, re-frozed snow. Which is why I carry my snow shovel in my roof basket during the winter. Link to comment Share on other sites More sharing options...
Liftedlego96 Posted December 15, 2021 Author Share Posted December 15, 2021 It all depends. I leave for work before the plows take care of the roads. The snow drifts are my biggest concern. I had an 03 forester that I've almost burried several times. Luckily id always make it threw without stopping completely but i dont want to be in a snow storm trying to unburry myself when the next half awake bozo comes bursting threw the snow drift im stuck in lol plus my back isnt as strong as it used to be. If i could put my snow blower up top i definitly would ha 1 Link to comment Share on other sites More sharing options...
laegion Posted December 15, 2021 Share Posted December 15, 2021 6 hours ago, Liftedlego96 said: It all depends. I leave for work before the plows take care of the roads. The snow drifts are my biggest concern. I had an 03 forester that I've almost burried several times. Luckily id always make it threw without stopping completely but i dont want to be in a snow storm trying to unburry myself when the next half awake bozo comes bursting threw the snow drift im stuck in lol plus my back isnt as strong as it used to be. If i could put my snow blower up top i definitly would ha I'm willing to bet you have enough clearance now....What will you be running for tires? Link to comment Share on other sites More sharing options...
Liftedlego96 Posted December 15, 2021 Author Share Posted December 15, 2021 Im thinking so. I currently have a set of new studded goodyear winter comand's 205/65/16 nothing massive but definitely an updrage from the 185/60/14's that were on it before i installed the forester struts. 1 Link to comment Share on other sites More sharing options...
