nelstomlinson Posted December 17, 2021 Share Posted December 17, 2021 '96 Legacy, 2.2L automatic. The exhaust pipe was loose on the end of the catalyst. This is the joint where there are two bolts with springs to hold it together. It looks as if the bolts were connected to two ears or a collar or something on the back of the cat, but whatever they connected to is almost entirely rusted away. Also, was there a gasket in there? I picked some crud out, but not sure if it was old gasket or just mud and carbon. What was this? What do I ask for at the parts store? Is there a workaround? Link to comment Share on other sites More sharing options...
forester2002s Posted December 17, 2021 Share Posted December 17, 2021 (edited) It's called a 'donut'. It's basically a thick gasket, designed to accommodate minor-misalignment of the joint. I think that you can buy a kit that includes the bolts, springs and a donut. EDIT: Found this online; no guarantee that this is the correct donut for your car, but this is probably what you're looking for: Catalytic Converter Gasket (Rear) But you'll need those 'ears' to squeeze the donut and to get a seal. Edited December 17, 2021 by forester2002s Link to comment Share on other sites More sharing options...
nelstomlinson Posted December 18, 2021 Author Share Posted December 18, 2021 I think that was the info I needed. I looked on Rockauto and found this diagram: https://www.rockauto.com/en/moreinfo.php?pk=2993826&cc=1269873&pt=5836 Looks as if the round gasket and the bolt kit will do it. The ears are rusted far beyond reuse, but I can fab them easily. In the mean time, the car has a mean sound with no muffler. Link to comment Share on other sites More sharing options...
lmdew Posted December 19, 2021 Share Posted December 19, 2021 I have good mid pipes if you want one. You pay shipping from 80919 Colorado. 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 19, 2021 Share Posted December 19, 2021 These guys have all the parts you need covered with simple kits: https://fxexhaust.com/pr/subaru.html GD 1 Link to comment Share on other sites More sharing options...
nelstomlinson Posted December 20, 2021 Author Share Posted December 20, 2021 GeneralDisorder, looks as if that kit you linked will slip onto the end of the cat, probably need a ubolt to clamp it? There is a ridge around the cat's output pipe, and that's what I figure I can fab ears to grab. It looks as if that was how it worked originally. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 20, 2021 Share Posted December 20, 2021 I would weld it to the cat, but could probably clamp it - or use an expander and then clamp it. Dealers choice. They sell both sides so you can purchase both and then attach with welding or clamps and then no fab is required. For the price I wouldn't bother with fabrication. But it's your time vs. money that's the question not mine. GD Link to comment Share on other sites More sharing options...
