"LO" light on Instrument Panel -1998 Forester - Got it.
1998 Forester, 5-speed
EDIT: Yes, I'd grounded/shorted the unused 'dual-range' transmission wiring. Wiring was cracked open just past where it was taped to the the wiring loom/harness on passenger side of bellhousing.
 - Working on adding a turbo (which I've done on other Subarus w/out issue) and after I got it all back together and started up, I now have this 'LO' light on the dash panel.
I found online that it's for the 'Low Range' , dual-range tranmission available in NON-USA models, which mine most definitely does NOT have. It has the original 5-speed transmission.
I'm guessing it's due to re-organizing the 3 main engine harness connectors to  make room for the turbo and related items (it's  very tight in that area).
Or maybe I accidently grounded one of those 'extra'/unused connectors on top of the transmission bell housing....which activated the light???
But sometimes Subaru's ECU/ECM will give a false reading, which actually means something else.
If y'all have any feedback. let me know.
Thanks and Happy Holidays!
Edited by wtdash
