PrinterTechnician Posted December 23, 2021 Share Posted December 23, 2021 (edited) So I've been tasked with assisting my less mechanically inclined friend with a complete suspension refresh on an 87 Brat GL 4-speed with dual range. From what I've gathered the Brat stayed on the "2nd gen" older chassis here in the states until it was cancelled in 1987. I've also determined that no one is currently making a front strut for the 2nd gen chassis as of this year. After all my searching I've only really found people converting to the 3rd gen suspension setup. So what have the 2nd gen Leone owners been doing about this? My concerns on converting would be finding a donor. Not many old Subarus sitting out in West Texas. Edited December 23, 2021 by PrinterTechnician Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 24, 2021 Share Posted December 24, 2021 it may be as useful as Aussies looking up US based parts providers, to you. But, have a look at our retailer of suspension stuff Pedders, they may do a listing, and may just ship to the US Use 1984 as a search year often helps disregard GEN3 EA82 (some markets still EA71) L Series 1985 to 1994 items that generally won't fit Link to comment Share on other sites More sharing options...
PrinterTechnician Posted December 24, 2021 Author Share Posted December 24, 2021 On 12/24/2021 at 1:16 AM, Step-a-toe said: it may be as useful as Aussies looking up US based parts providers, to you. But, have a look at our retailer of suspension stuff Pedders, they may do a listing, and may just ship to the US Use 1984 as a search year often helps disregard GEN3 EA82 (some markets still EA71) L Series 1985 to 1994 items that generally won't fit Expand I found an eBay listing here that explicitly says it won't ship to the US. Pedders didn't seem to have any fronts available on their AU site. I guess I could ask about international shipping. Link to comment Share on other sites More sharing options...
6 Star Posted December 24, 2021 Share Posted December 24, 2021 (edited) @PrinterTechnician have you been searching for the parts with "1987" in your search? That will bring up parts for a 3rd gen, which isn't what you are looking for. Do as Step-a-toe says and use either 1982, 1983, or 1984 in your search. Those are years where there was zero generation crossover (in the US) and will net you more positive results. Assuming you already checked rock-auto and all the major chain stores; VatoZone, O'Highlys, CRAPA, etc... you can also check Speed Shops near you that deal in Imports. Around me are several "Autosport Import" parts shops. Best of luck in your repair work Edited December 24, 2021 by 6 Star Link to comment Share on other sites More sharing options...
6 Star Posted December 24, 2021 Share Posted December 24, 2021 Also, look into using the 3rd gen Suspension on the Brat... I'm not well versed in the conversion... but would guess that the setup would have to be something like this; EA81 Tophats EA82 strut and spring EA82 Knuckles, etc EA82 Axles Not sure if EA82 axles fit to the EA81 trans... might have to make hybrid axles or convert the Brat to 5 Speed DualRange... Anyway... its always simpler to swap stock with stock... stay all EA81 would be my vote Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 24, 2021 Share Posted December 24, 2021 On 12/24/2021 at 2:44 AM, 6 Star said: @PrinterTechnician have you been searching for the parts with "1987" in your search? That will bring up parts for a 3rd gen, which isn't what you are looking for. Do as Step-a-toe says and use either 1982, 1983, or 1984 in your search. Those are years where there was zero generation crossover (in the US) and will net you more positive results. Assuming you already checked rock-auto and all the major chain stores; VatoZone, O'Highlys, CRAPA, etc... you can also check Speed Shops near you that deal in Imports. Around me are several "Autosport Import" parts shops. Best of luck in your repair work Expand with front struts, use 1984. If you use earlier years, they ran inserts or cartridges fitted into the main assembly of a strut. I looked on Pedders site and it was not a good look. Some items at least gave a heads up that the deletion of said part was pending. Just when these things are going up in demand and new owners prepared to spend on them !! Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 24, 2021 Share Posted December 24, 2021 On 12/24/2021 at 2:49 AM, 6 Star said: Also, look into using the 3rd gen Suspension on the Brat... I'm not well versed in the conversion... but would guess that the setup would have to be something like this; EA81 Tophats EA82 strut and spring EA82 Knuckles, etc EA82 Axles Not sure if EA82 axles fit to the EA81 trans... might have to make hybrid axles or convert the Brat to 5 Speed DualRange... Anyway... its always simpler to swap stock with stock... stay all EA81 would be my vote Expand EA82 front CV shafts are about 40mm longer than EA81 for starters. Top hats - EA82 use a bearing that has larger ID than that of the bush in EA81 top hats - Link to comment Share on other sites More sharing options...
PrinterTechnician Posted December 24, 2021 Author Share Posted December 24, 2021 On 12/24/2021 at 2:44 AM, 6 Star said: @PrinterTechnician have you been searching for the parts with "1987" in your search? That will bring up parts for a 3rd gen, which isn't what you are looking for. Do as Step-a-toe says and use either 1982, 1983, or 1984 in your search. Those are years where there was zero generation crossover (in the US) and will net you more positive results. Assuming you already checked rock-auto and all the major chain stores; VatoZone, O'Highlys, CRAPA, etc... you can also check Speed Shops near you that deal in Imports. Around me are several "Autosport Import" parts shops. Best of luck in your repair work Expand On 12/24/2021 at 5:21 AM, Step-a-toe said: with front struts, use 1984. If you use earlier years, they ran inserts or cartridges fitted into the main assembly of a strut. I looked on Pedders site and it was not a good look. Some items at least gave a heads up that the deletion of said part was pending. Just when these things are going up in demand and new owners prepared to spend on them !! Expand I've been using 1984 in my searches. No major chain, rockauto, or any other online retailer has anything for the front. I checked some specialty shops with an online storefront (mostly out of California) all with their sketchy 90s looking websites. Only place that listed them available was 2kracing.com. When I called them the guy was quick to tell me "yeah all the Subaru brat guys keep calling but we haven't had any in some time" so that was a dead end. The last company that appears to have produced them in the US was KYB under part# 234028. I really don't think an EA82 suspension conversion is in the cards. I'm going to seriously consider trying to get some shipped from Australia. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 24, 2021 Share Posted December 24, 2021 Subaru brought some in about 1 to 2 years ago. Half a dozen sets IIRC. These are the factory style with the lower perch height adjusters. Those of us that knew about it snapped them up. Don't know if such an occurrence will happen again - seems highly unlikely. Not sure if I will use the set I have for my hatch or just convert to a better front suspension system when I go to the Toyota transmission and EJ22...... I would sell the set I have (new in Subaru boxes - never opened) but I want $1500 + shipping for the pair. GD Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 25, 2021 Share Posted December 25, 2021 all I used to convert was the EA82 front strut complete with the coil spring and the EA82 strut top mount. if you observe the jelly bean shape washers atop your strut towers - I made some more to loose fit on top of the new holes made to take the three stud EA82 mounts. I used an old three stud mount that had a missing or broken stud, removed two and used the remaining stud to bolt up to the front hole of the 2 hole strut tower - from under neath I think, in order to line up the new holes by using removed stud holes as the guide. I retained EA81 knuckles, CV shafts and brakes. I think I used L Series brake hoses as well. Little work around their retainers due to me not working out that whoever fitted the new Sachs? to my turbo EA82 sedan, had fitted left to right, and right to left despite idiot proof diagram fitment stickers ! 1 Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 25, 2021 Share Posted December 25, 2021 On 12/24/2021 at 9:10 AM, GeneralDisorder said: Subaru brought some in about 1 to 2 years ago. Half a dozen sets IIRC. These are the factory style with the lower perch height adjusters. Those of us that knew about it snapped them up. Don't know if such an occurrence will happen again - seems highly unlikely. Not sure if I will use the set I have for my hatch or just convert to a better front suspension system when I go to the Toyota transmission and EJ22...... I would sell the set I have (new in Subaru boxes - never opened) but I want $1500 + shipping for the pair. GD Expand 721032064 the ones you are talking about GD ? Link to comment Share on other sites More sharing options...
Steptoe's photos Posted December 25, 2021 Share Posted December 25, 2021 (edited) Photo. The box make all the difference on price or value? We only got them in plastic bags ! Edited December 25, 2021 by Steptoe's photos Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 25, 2021 Share Posted December 25, 2021 that number is a fits both left and right part. I think earlier numbers were handed. It might be six years since i ordered these from my local dealer. I would not take $1500 for the pair, now that they are like gold Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 25, 2021 Share Posted December 25, 2021 These most recent one's that Subaru brought in a couple years ago did come in boxes, yes. IIRC they are left and right because of the brake line mounting brackets and possibly the location of the tab that bolts to the knuckle. And yes they are basically unobtainable. Just like EA81/EA82 oil pumps. I have a friend with some parts stashed and recently someone wanted an EA81 oil pump. He quoted them $500 and I was like - why so cheap? I remember buying them from the dealer 15 years ago for $65. Such is the way it goes. These vehicles are now collectibles. They are not viable drivers unless the entire drivetrain is updated and even then if you need trim or glass - you'll be off the road for a long stretch trying to find it. And people wonder why I drive old Chevy's and military vehicles. GD 1 Link to comment Share on other sites More sharing options...
6 Star Posted December 25, 2021 Share Posted December 25, 2021 On 12/25/2021 at 3:02 AM, GeneralDisorder said: And people wonder why I drive old Chevy's and military vehicles. GD Expand I would too if I had the Space and Coin for Gas... love the SBC and the Ford Inline-6 300 I debated selling or giving away parts in the past... heck 5 or 6 years ago I threw away parts that are probably Gold now... Glad I've hoarded what I have now 1 Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 25, 2021 Share Posted December 25, 2021 agreed, something is happening. I still daily my 89 Brumby with EA82 drivetrain, parks next to the 87.5 Vortex. Am working on helping a Euro out with some EA81 heads. He was quoted 800 euro for a pair of take them as you get them used heads !! Link to comment Share on other sites More sharing options...
Step-a-toe Posted December 25, 2021 Share Posted December 25, 2021 On 12/25/2021 at 3:02 AM, GeneralDisorder said: These most recent one's that Subaru brought in a couple years ago did come in boxes, yes. IIRC they are left and right because of the brake line mounting brackets and possibly the location of the tab that bolts to the knuckle. And yes they are basically unobtainable. Just like EA81/EA82 oil pumps. I have a friend with some parts stashed and recently someone wanted an EA81 oil pump. He quoted them $500 and I was like - why so cheap? I remember buying them from the dealer 15 years ago for $65. Such is the way it goes. These vehicles are now collectibles. They are not viable drivers unless the entire drivetrain is updated and even then if you need trim or glass - you'll be off the road for a long stretch trying to find it. And people wonder why I drive old Chevy's and military vehicles. GD Expand The part in the pic above has a bracket that does brake line for left and right Link to comment Share on other sites More sharing options...
newmexguy Posted December 27, 2021 Share Posted December 27, 2021 (edited) Three BRATS still available in Bent, NM on Las Cruces NM craigslist. Were there a week or so ago, with a few general pictures. Package deal - believe it was $1400 for THREE mid eighties BRATS. Should be clean metal on those vehicles. Dave S las Cruces Edited December 27, 2021 by newmexguy Link to comment Share on other sites More sharing options...
PrinterTechnician Posted February 5, 2022 Author Share Posted February 5, 2022 I considered a package forwarding service from Australia. But that would cost about $550USD for just the struts and then another $500USD+ in shipping to the US. My friend is not interested in doing the EA82 suspension conversion. The easiest option would be knowing someone in Australia who could ship the parts to the US for a reasonable price. Or convincing a US vendor that there is a market for these. Which I doubt would be possible with how few of these are rolling around. Link to comment Share on other sites More sharing options...
6 Star Posted February 5, 2022 Share Posted February 5, 2022 @PrinterTechnician You would be surprised how many EA81 and EA82 Generation cars are still out there, even as daily drivers. If you got enough people together to do a group buy... just sayin, its been done in the past... finding the right Manufacturer and Group to buy in with is the harder part Link to comment Share on other sites More sharing options...
el_freddo Posted February 5, 2022 Share Posted February 5, 2022 There is no “reasonable” shipping from Australia. It’s WAY cheaper to send stuff in from overseas, but sending it out/back to the point of origin would cost easily double. It’s a joke. Pack and Send might be the best option but could be quite slow. Someone would have to go and investigate. Cheers Bennie Link to comment Share on other sites More sharing options...
