logic23 Posted January 24, 2022 Share Posted January 24, 2022 Just posting this to avoid any dangerous situations. On the phase 2 EJ engines intakes there are 3 sections of around 3 inch high pressure line: one on the drivers side just below where the fuel lines from the car connect one on the front passengers side ( partially covered by metal shield on some models) and one in the back going to the fuel pressure regulator The first 2 are the ones that i have seen leaking regularly I think that over time the fuel line shrinks with age so the hose clamps are no longer tight. Just a couple turns will usually stop the leaking. Make sure you have the proper philips head so that you dont strip them Some times it takes a little work to rotate the clamps around so that you can easily get to them with a screw driver. I tightened the ones on my 2002 forester S over the summer but last week wiht the extreme cold we had here in Ohio mine started leaking again. Turned the clamps a little more and havent seen anymore leaks. So please check yours and keep a nose out for gas fumes. I can add some pics if people would like Thanks 1 Link to comment Share on other sites More sharing options...
