mickytrus Posted January 25, 2022 Share Posted January 25, 2022 I noticed that the upper hose, rad outlet... where the hose mounts to radiator is a little compromised. There is supposed to be that little ridge(can think of it sorta like a ferrule) that is on the edge of the mounting nipple which is there to keep a tightened hose from sliding off.. You get my picture, you kno what I am talking about. https://images-na.ssl-images-amazon.com/images/I/81vZI%2B9X2eL._SL1500_.jpg link to,, just be for reference showing what a healthy outlet or inlet to radiator looks like. Mine has somehow disappeared. has broken off. I am wondering what is the plastic that these radiators are made out of? does anybody know? I am guesing ABS plastic?(just Cuz it is black) What I am thinking is that maybe I can use some glue to create a new ridge. for peace of mind. (cuz I have the hose on there now... it is not leaking... just need to Mod this problem... so not to buy another radiator because of this problem... this radiator is in excellent shape... thanks, MIcky Link to comment Share on other sites More sharing options...
heartless Posted January 25, 2022 Share Posted January 25, 2022 make sure the hose is all the way on, and clamped properly. if it isnt leaking, leave it alone. and just because it is black means absolutely nothing. I have ABS materials for 3d printing in all colors of the rainbow, including black... Lego is ABS plastic. I also have other materials in many colors, including black - so the color means nothing. doing a google search says the plastic parts on a radiator are high temp nylon Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 25, 2022 Share Posted January 25, 2022 Replace the radiator. It's garbage. Welcome to modern cars. Radiators last 8-10 years max. GD 2 Link to comment Share on other sites More sharing options...
idosubaru Posted January 25, 2022 Share Posted January 25, 2022 On 1/25/2022 at 2:25 AM, mickytrus said: this radiator is in excellent shape... Expand No, it's not. Research shows a 50% molecular degradation after 100,000 miles in radiator plastics. Replace or leave it be, but I wouldn't try "building it up" or repairing it. What you saw is very common, the outlets do this all the time. I've never worked at a shop and still seen it a bunch of times. 2 Link to comment Share on other sites More sharing options...
el_freddo Posted January 25, 2022 Share Posted January 25, 2022 That’s your indicator to replace the radiator with another unit - go for quality or replace more frequently. Or leave the radiator and do your repair. That end tank WILL fail and it will kill your engine as a result. Been there done that. For me it happened at the worst possible time/place. We were 600km from home. HGs were shot when we replaced the radiator. Your call. I’m with GD and Ido on this one, I highly recommend you get a new radiator. Cheers Bennie Link to comment Share on other sites More sharing options...
mickytrus Posted January 25, 2022 Author Share Posted January 25, 2022 Yeah, You go through all the trouble, get the car so you can drive it on a long trip and bite tooth and nail. Cuz the radiator is fck'd....(plastics become britte no matter what)..& and will keep breakin.. Yeah, The reason I did this clutch was the last ride was too suspenseful. (road trip to "God's Country") Hoping I got the momentum to get up a hill Tires are not slipping in the sno... but, the clutch is slippin on the hill (go figure) What are recommended brands to replace it with? Thanks, Micky Link to comment Share on other sites More sharing options...
mickytrus Posted January 26, 2022 Author Share Posted January 26, 2022 For little more dough.... Might be the way to go.... Anybody got one of these? https://www.ebay.com/itm/173310313540?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D236622%26meid%3Dd64fe4efcd1244abad6ee80ce6f234ed%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D265461050503%26itm%3D173310313540%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeed%26brand%3DSubaru&_trksid=p2047675.c101195.m1851&amdata=cksum%3A173310313540d64fe4efcd1244abad6ee80ce6f234ed|enc%3AAQAGAAACIBZVppsKd7ns%2F6V0zsrSqiF%2FdU19mgn%2FdPTwQp31iM%2F9arBfaO0jDjbdqFPAwu7G7BJPQp1V4WKqrOSBctdQCaVEKPiknkwgL%2BK0JBg4ynNiNCRQhDjfTKbzEcEGAS6wHt4k34DyF%2FtwXpvxzQbX7lwzV7H2IKQwR5r3dVSthA%2Bh2YwG%2FTnvOhpJdUjayKgeRAucQl%2FSSFZwvWuJMyleqtaSm2xfC43iVTFBt4y9SJ0RgcpTmzrsKdKyxN4kW3KM1RLHp5%2BCnFa72Xk2bLpvo0NW4%2Bgrr6IEID0YP69e96gvdz2yamUr3sIAM6bbdrLRt72FjZcfwLzcRWKQXN0%2FR%2FhKirAQ34yWjXwIEeDZ8ImAyHBT21qDuutpwYAt6oXYHi13VCmNqBH2pSqZfKZ4yLYORSZLptvpM%2BvEv4oGkBoMMldkt39xh9rzWVixHkU7LsQhEPFdmy9iGSxdpTFzNf7dKC%2BSbW6BpyX1gvUg19b6dgJM8AzpdRR5civ6RaY26g9rtdmzaWCyEpWGAQyBDqd%2Be%2B4CGHlz5AuYDF%2B33DYK%2BodqoL5%2Fskp9OXKeaLltuFGUGLPxzGm25cXDghSokmqTreuLHOlBV%2FyeNs6cY4VxzAObphjBRgZnjEfuzuXd6h8h8%2B1zo%2B0b%2FEXjulLWOfHDNNX0vd%2B8r8Cay02RQl8R9Wqp5D7xGdi0kH4v8rHbGdA%2FDdP20hm9sie7S46N4qM%3D|ampid%3APL_CLK|clp%3A2047675&epid=2183926058 Link to comment Share on other sites More sharing options...
mickytrus Posted January 28, 2022 Author Share Posted January 28, 2022 Yeah, So I went ahead and got one of these pups. Will post on how it goes. quality build etc. etc. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 28, 2022 Share Posted January 28, 2022 The usual scumbag Chinese aluminum radiators from ebay typically have a lot of fitment issues. Good luck. The 96 Legacy GT and some of the Outback's from the generation had copper/brass radiators. I would have looked for one of those. GD Link to comment Share on other sites More sharing options...
mickytrus Posted March 9, 2022 Author Share Posted March 9, 2022 Thanks!... It went ok..... Link to comment Share on other sites More sharing options...
laegion Posted March 10, 2022 Share Posted March 10, 2022 (edited) On 3/9/2022 at 11:50 PM, mickytrus said: Thanks!... It went ok..... Expand Just, Okay? That sounds ominous...I just bought a stock Denso radiator for my '03, not from the dealer though, on ebay. It cost me about what a generic brand costs at the big parts stores ~$120. Just did the same for my '95. They are typically the o.e.m. manufacturer for Japanese car brands. The trick is to be sure what you're buying is genuine. I typically only buy stuff like that from sellers with 99% or higher feedback just to be safe...and also make sure they specify the brand in the sale, so I can get my money back if they try to switch it on me. Edited March 10, 2022 by laegion Link to comment Share on other sites More sharing options...
laegion Posted March 10, 2022 Share Posted March 10, 2022 On 1/26/2022 at 12:22 AM, mickytrus said: For little more dough.... Might be the way to go.... Anybody got one of these? https://www.ebay.com/itm/173310313540?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D236622%26meid%3Dd64fe4efcd1244abad6ee80ce6f234ed%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D265461050503%26itm%3D173310313540%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv9PairwiseWebMskuAspectsV202110NoVariantSeed%26brand%3DSubaru&_trksid=p2047675.c101195.m1851&amdata=cksum%3A173310313540d64fe4efcd1244abad6ee80ce6f234ed|enc%3AAQAGAAACIBZVppsKd7ns%2F6V0zsrSqiF%2FdU19mgn%2FdPTwQp31iM%2F9arBfaO0jDjbdqFPAwu7G7BJPQp1V4WKqrOSBctdQCaVEKPiknkwgL%2BK0JBg4ynNiNCRQhDjfTKbzEcEGAS6wHt4k34DyF%2FtwXpvxzQbX7lwzV7H2IKQwR5r3dVSthA%2Bh2YwG%2FTnvOhpJdUjayKgeRAucQl%2FSSFZwvWuJMyleqtaSm2xfC43iVTFBt4y9SJ0RgcpTmzrsKdKyxN4kW3KM1RLHp5%2BCnFa72Xk2bLpvo0NW4%2Bgrr6IEID0YP69e96gvdz2yamUr3sIAM6bbdrLRt72FjZcfwLzcRWKQXN0%2FR%2FhKirAQ34yWjXwIEeDZ8ImAyHBT21qDuutpwYAt6oXYHi13VCmNqBH2pSqZfKZ4yLYORSZLptvpM%2BvEv4oGkBoMMldkt39xh9rzWVixHkU7LsQhEPFdmy9iGSxdpTFzNf7dKC%2BSbW6BpyX1gvUg19b6dgJM8AzpdRR5civ6RaY26g9rtdmzaWCyEpWGAQyBDqd%2Be%2B4CGHlz5AuYDF%2B33DYK%2BodqoL5%2Fskp9OXKeaLltuFGUGLPxzGm25cXDghSokmqTreuLHOlBV%2FyeNs6cY4VxzAObphjBRgZnjEfuzuXd6h8h8%2B1zo%2B0b%2FEXjulLWOfHDNNX0vd%2B8r8Cay02RQl8R9Wqp5D7xGdi0kH4v8rHbGdA%2FDdP20hm9sie7S46N4qM%3D|ampid%3APL_CLK|clp%3A2047675&epid=2183926058 Expand Please tell me it wasn't $999 when you bought one?? Link to comment Share on other sites More sharing options...
