Sjoubert928 Posted February 5, 2022 Share Posted February 5, 2022 First time posting, but have browsed the forum numerous times. I got a 1992 Loyale and - regardless of the parking light switch position - the parking lights stay on. I've tried to do research on it to no avail as everything points to checking that switch. I checked the under dash fuses and even pulled the parking switch off to check to no avail. Is there anything i'm missing or do I have a wiring mystery on my hands? Link to comment Share on other sites More sharing options...
el_freddo Posted February 5, 2022 Share Posted February 5, 2022 There’s a switch on top of the steering column, flick this off and it should turn the Parkers off. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 5, 2022 Author Share Posted February 5, 2022 21 minutes ago, el_freddo said: There’s a switch on top of the steering column, flick this off and it should turn the Parkers off. Cheers Bennie That's my issue, it doesn't matter whether that rocker switch is flicked onto the off or on position on the column - they stay on regardless. I even pulled the switch rocker out and tried manually jumping the contacts to be sure. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 5, 2022 Share Posted February 5, 2022 (edited) not sure about a '92, but some soobs have issues with the 1157 type bulbs(filaments sagging/shorting) OR those type of bulb sockets(corrosion). Maybe check those out? Edited February 5, 2022 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 6, 2022 Author Share Posted February 6, 2022 1 hour ago, 1 Lucky Texan said: not sure about a '92, but some soobs have issues with the 1157 type bulbs(filaments sagging/shorting) OR those type of bulb sockets(corrosion). Maybe check those out? Just pulled those to check albeit I don't have new bulbs until the morning - does seem to reduce load on that circuit. Am finding it is putting load onto the Hazard / Clock / Horn fuse and blowing it oddly enough when I open the trunk which triggers the ajar dash light. Just watched the front Markers pulse / get dimmer with the motor running before turning off though with the rear bulbs removed and a new fuse. I definitely got something screwy in the circuit here. Thanks for the tip! Link to comment Share on other sites More sharing options...
el_freddo Posted February 6, 2022 Share Posted February 6, 2022 Ah righto! Definitely sounds like there’s something screwy at play. Hopefully it’s an easy/simple fix. Cheers Bennie Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 6, 2022 Share Posted February 6, 2022 I wouldn't rule-out an issue with the harness going from the body to the hatch. shorting out or ??? 1 Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 7, 2022 Author Share Posted February 7, 2022 (edited) 7 hours ago, 1 Lucky Texan said: I wouldn't rule-out an issue with the harness going from the body to the hatch. shorting out or ??? Funny you say that - put one bulb back in first thing this morning and that exact pigtail nearly started an electrical fire - issue found! Just lucky I was back there doing that versus driving! Needless to say I had to cut power and cut the self -shorting pigtail after I snuffed it. Got too cooked though to know which wires were going to which to re-wire easy though - is there any online diagrams available or does anyone have a picture from there own car of that rear passenger connection? Edited February 7, 2022 by Sjoubert928 Added pictures for detail 1 1 Link to comment Share on other sites More sharing options...
moosens Posted February 8, 2022 Share Posted February 8, 2022 Holy cow you’re in Lee Mass. ? Cool to see other New England classics. That being the case I’d also begin to investigate other electrical areas like the power window relay under the drivers seat. And maybe there’s something on the floor of the passenger side too ? Having owned enough of those here in CT I can tell you those are notorious for corrosion. Good luck with it. Enjoy ! Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 8, 2022 Author Share Posted February 8, 2022 10 hours ago, moosens said: Holy cow you’re in Lee Mass. ? Cool to see other New England classics. That being the case I’d also begin to investigate other electrical areas like the power window relay under the drivers seat. And maybe there’s something on the floor of the passenger side too ? Having owned enough of those here in CT I can tell you those are notorious for corrosion. Good luck with it. Enjoy ! Yep, although the wagon is originally from Essex County on the coast. Old lady garaged it and used it for bread and milk so I got it at 66K on the odometer last August. Not too bad as a result in terms of rust and corrosion but i'll definitely check those after dealing with this! 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 8, 2022 Share Posted February 8, 2022 ah, I think you really need to inspect for rodent damage as well. 2 Link to comment Share on other sites More sharing options...
DaveT Posted February 9, 2022 Share Posted February 9, 2022 I'm in CT. I have an 87 and a 93, almost the same as far as this stuff. I can't tell where that picture is - up under the dash, down near the feet? 1 Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 9, 2022 Author Share Posted February 9, 2022 16 hours ago, DaveT said: I'm in CT. I have an 87 and a 93, almost the same as far as this stuff. I can't tell where that picture is - up under the dash, down near the feet? This is behind the passenger tail light assembly - it's the pigtail that connects the main harness to the hatch for the wiper motor, plate lights, defroster etc Link to comment Share on other sites More sharing options...
Sjoubert928 Posted February 9, 2022 Author Share Posted February 9, 2022 On 2/8/2022 at 10:11 AM, 1 Lucky Texan said: ah, I think you really need to inspect for rodent damage as well. On my list after this - havn't found much in that regard working under the hood and around the car but that means nothing for under the carpets and panels. 1 Link to comment Share on other sites More sharing options...
