1988 GL Transmission
At this age, finding one is a hill.  All of mine are the 3AT 3 speed auto 4WD.  all around 150K - 200K miles.   None have had serious massive failures, except the one that was run with no differential oil for too long because of an unknown slow leak...  Even that one, the transmission parts are still good.      Some of the guys that are running the manuals or AWD might know how many miles they should be good for.
If you find an EA82 AWD gearbox it will bolt in the same as any of the EA82 4wd gearboxes.
Grab the solenoids off the LHS strut tower for the locked centre diff actuation.
In these the front and rear diff ratios MUST be a match or you’ll stuff the centre diff - and this item is harder to find than one of these AWD gearboxes!
Cheers
Bennie
