Queen Sadim Posted February 22, 2022 Share Posted February 22, 2022 Yesterday, when I shut of the ignition, the stereo cranked out loud radio static. I was unable to reduce the volume or turn off the stereo, even when the car was running. My boyfriend tried pulling the fuse, to no avail. He then disconnected the battery, when he reconnected it, the problem was solved, however, the right signal is now stuck on. When I switch the arm to off position or to signal left, nothing changes, right signal remains on. I tried driving the car and turning the wheel to disengage the signal. No luck. Then my bf tried pulling that fuse, which also did nothing. Any suggestions as what to try next pls? Link to comment Share on other sites More sharing options...
lmdew Posted February 22, 2022 Share Posted February 22, 2022 Sounds like you have a short somewhere providing complete circuit for power. Has any work been accomplished lately? Any previous damage to the car? Main relays are up under the drivers side dash. They are way up there under the kick panel. Next time it happens I'd try pulling the relays. Do you have an aftermarket security or remote start system installed? 1 Link to comment Share on other sites More sharing options...
