85 Subaru Brat 4wd No spark from Coil
Was driving around then the car suddenly stop running Replaced coil, fuel pump, couldn't find a replacement pick up coil/ignition control module so bought new disty off Rock Auto still no spark. Any info/Help will be appreciated.
You need to replace the ignition module in the dizzy.
Having already replaced the coil, if it’s new, you’ll know the ignition module is safe. Often the coil dies, killing the ignition module with it.
Cheers
Bennie
