ThosL Posted April 7, 2022 Share Posted April 7, 2022 I've noticed that there is considerable variations on reading the oil level with the dipstick depending on the asphalt surface I am on. Is there any way to know whether you are on a level surface? Link to comment Share on other sites More sharing options...
moosens Posted April 7, 2022 Share Posted April 7, 2022 (edited) What I can add to this is we have a 1993 2.2 which can read zero oil the first couple of minutes almost and then later will show actual level. This caused a full serve guy (sorry but my wife uses full serve) over filling the engine once. Like significantly. None of our older Subarus ever had this problem. Seems to me these newer engines can be a bit retentive when checking oil quickly after stopping. I have begun to crack the filler cap open to breathe is out a bit and hope the best. As for level ground, Have a ball ? Dog toy in our case. Place the ball down and watch if it rolls. Carry a cheapie HF torpedo level if it’s that critical. A little degree or two should not cause a huge difference. Edited April 7, 2022 by moosens 1 Link to comment Share on other sites More sharing options...
heartless Posted April 7, 2022 Share Posted April 7, 2022 if it looks reasonably level to they eye, it should be fine. some parking lots are obviously on a slope, others look reasonably level.. does not need to be dead level, but not on an obvious slope either.. if you are checking oil level when getting gas, check it last, not first... ie: pump your gas, clean windshield, etc.. then check oil level last. 4 Link to comment Share on other sites More sharing options...
forester2002s Posted April 8, 2022 Share Posted April 8, 2022 On my 2002 EJ2.5, I have to let the engine get cold (I leave it overnight), and I have to wipe the dipstick dry before checking the oil level. That's the only way that I can get a decent reading. On my 2017 FB2.5, if I check it in the morning with the engine cold, the dipstick comes out the first time with a good reading, even without wiping it clean (someone at the Subaru design office has finally figured out how to design a dipstick that works!) Link to comment Share on other sites More sharing options...
ThosL Posted April 8, 2022 Author Share Posted April 8, 2022 Thanks for the advice. On my newly purchased 2002 Forester I have overfilled it; there seems to be a lot of variability and was not sure what caused that, I thought it could only be the asphalt it was on not being level which can be hard to ascertain. Link to comment Share on other sites More sharing options...
heartless Posted April 9, 2022 Share Posted April 9, 2022 13 hours ago, ThosL said: Thanks for the advice. On my newly purchased 2002 Forester I have overfilled it; there seems to be a lot of variability and was not sure what caused that, I thought it could only be the asphalt it was on not being level which can be hard to ascertain. yeah, the 02 i had could be difficult at times. but letting it sit for a few minutes... pull dipstick, wipe well, and then check usually gives a reasonable view. letting it sit overnight almost invariably showed slightly over full.. but check it within an hour of being run and it was pretty much dead on every time. 1 Link to comment Share on other sites More sharing options...
ThosL Posted April 11, 2022 Author Share Posted April 11, 2022 I overfilled it because cold it was low on the dipstick. I assumed it was burning oil and put in way too much. I wonder if that had anything to do with the catalytic converter getting clogged. Link to comment Share on other sites More sharing options...
heartless Posted April 12, 2022 Share Posted April 12, 2022 yes, it could Link to comment Share on other sites More sharing options...
