Gypsybaron3 Posted April 25, 2022 Share Posted April 25, 2022 Hi! I AM done h6 swap in to my 98 Impreza gf. I just need some help with VSS wiring! Any ideas? 1 Link to comment Share on other sites More sharing options...
idosubaru Posted April 26, 2022 Share Posted April 26, 2022 Well done! Don't know about the VSS. What issue are you having with it? Did you swap into an auto or manual vehicle? 1 Link to comment Share on other sites More sharing options...
Gypsybaron3 Posted April 27, 2022 Author Share Posted April 27, 2022 17 hours ago, idosubaru said: Well done! Don't know about the VSS. What issue are you having with it? Did you swap into an auto or manual vehicle? Manual swap, 2 wire vss. Need to know have to connect correctly! Runs and drive, just need speedometer for technical inspection. Link to comment Share on other sites More sharing options...
lmdew Posted April 27, 2022 Share Posted April 27, 2022 There is a 2 pin blue connector on the back of the Dash. I believe that is the speedo connection. I'd check to see if you have it on the gauge cluster and then use the wiring manual to find the best place to connect you VSS to it. 1 Link to comment Share on other sites More sharing options...
el_freddo Posted April 28, 2022 Share Posted April 28, 2022 That engine in the impreza is a super mean package from what I’ve been told. I think there were two that were done over here at one point. Dunno what happened to them though. I hope the VSS wiring is a simple fix for you. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
Gypsybaron3 Posted April 28, 2022 Author Share Posted April 28, 2022 On 4/27/2022 at 8:00 PM, lmdew said: There is a 2 pin blue connector on the back of the Dash. I believe that is the speedo connection. I'd check to see if you have it on the gauge cluster and then use the wiring manual to find the best place to connect you VSS to it. Ok, i try! Tnx! Link to comment Share on other sites More sharing options...
