sirtokesalot Posted May 4, 2022 Share Posted May 4, 2022 (edited) ive been battling a stumble/misfire when taking off from a stop for the past month or so on my 2001 outback. so far ive changed the spark plugs changed the wires and coil pack and done a compression test witch came out to 175 175 175 and 165 after changing the plugs it did fix it for about 2 days but the issue returned the coil and wires dident do anything for it. compression seems good to me the engine did get all new gaskets bearings and rings 2 years ago. yesterday found a vacuum leak and no change by fixing that. i tried to reset the ecu by unhooking the battery and touching the 2 wires together for 10 seconds that did stop the stumble for about 30 minutes but it came back half way to work. air filter is good exhaust not plugged. what the hell is going on with the car? Edited May 4, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 4, 2022 Share Posted May 4, 2022 Have you pulled the plugs out to see if any of them are fouled? Leaking injector could foul a plug.... etc. Sounds like a classic misfire to me. Diamond coil, NGK plugs and wires? GD 1 Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 4, 2022 Author Share Posted May 4, 2022 (edited) On 5/4/2022 at 12:51 AM, GeneralDisorder said: Have you pulled the plugs out to see if any of them are fouled? Leaking injector could foul a plug.... etc. Sounds like a classic misfire to me. Diamond coil, NGK plugs and wires? GD Expand it does feel like a misfire. its not throwing any codes at all. the plugs are ngk wires and coil i robbed off my plow car "an 01 legacy sedan" witch was running fine and not misfiring at all.i did the compression check 2 or 4 days after doing the plugs and all the plugs looked same dident seem fouled out. once i get moving the miss stops and it runs smooth its only doing it when taking off from a stop or if i floor it to pass and the rpm is low enough. the miss/stumble also seems kind of random like its not happening every time it fires that cylinder. also while running if i unplug the wires from the coil all cylinders are contributing the idle will dip lower for each cylinder i pull the wire for. Edited May 4, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 4, 2022 Author Share Posted May 4, 2022 could this be a valve issue or a cam issue? or would that be more consistent Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 4, 2022 Author Share Posted May 4, 2022 (edited) Update it is becoming worst the more I drive it. Still no cel even thogh it will skip and miss from 0 up to 40ish on 4 out of 10 accelerations and the other 6 times would just be a stumble on take off. Edited May 4, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
forester2002s Posted May 4, 2022 Share Posted May 4, 2022 Could it be bad gas? But if you've been experiencing this 'misfire' 'for the past month or so', I would expect that you've had to refill the gas-tank a few times - if so, 'bad gas' would probably not be relevant. Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 4, 2022 Author Share Posted May 4, 2022 (edited) As of now it's starting to backfire and seems like it's more of an Ignition cut than a misfire I can't see it being bad guess I buy my gas the same station all the time And I fill it up twice a week Edited May 4, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 4, 2022 Share Posted May 4, 2022 check the vacuum line on the fuel pressure regulator for wetness/fuel. maybe try a throttle body cleaning? like the SeaFoam with the curved nozzle gadget. check the knock sensor for cracks. can you get live data or freeze-frame data? what are the fuel trims? ignition timing/knock events? 1 Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 5, 2022 Author Share Posted May 5, 2022 (edited) the fuel pressure regulator was my vacuum leak the other day no wetness at that. i dont beleive my scanner is capable of getting the data and fuel trims. heres 2 clips of how it is running starting from a stop and flooring it. dont mind the tape on the left of the dash its hiding the air bag light i was going to fix before this started happening badly. Edited May 5, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 5, 2022 Share Posted May 5, 2022 (edited) Yeah might want to check fuel pressure. Those cars are known for the metal cap inside the fuel pump assembly blowing off. Also may be a partially plugged exhaust. Do you have a gauge you can install into the O2 sensor port before the cat? Beyond that - don't expect to see misfire codes immediately - these ECU's are pretty dumb and may take a pretty severe misfire and running them for quite a little while before they toss code. GD Edited May 5, 2022 by GeneralDisorder Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 5, 2022 Author Share Posted May 5, 2022 On 5/5/2022 at 12:40 AM, GeneralDisorder said: Yeah might want to check fuel pressure. Those cars are known for the metal cap inside the fuel pump assembly blowing off. Also may be a partially plugged exhaust. Do you have a gauge you can install into the O2 sensor port before the cat? Beyond that - don't expect to see misfire codes immediately - these ECU's are pretty dumb and may take a pretty severe misfire and running them for quite a little while before they toss code. GD Expand i do know of the fuel pump cap issue however i was not aware it could happen and still let the car run. every time ive seen it the car wouldn't run at all. Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 5, 2022 Author Share Posted May 5, 2022 fuel pressure seems ok to me sit around 30 to 35 idle and comes up when reving the engine to around 40. Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 5, 2022 Author Share Posted May 5, 2022 update i pulled the drivers side valve cover off the side that had one cylinder lower compression than the rest checked valve clearance it was fine not sure what i did exactly but after putting it back together the miss/stumble is gone as of the moment. i dont really believe i fixed it though. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 5, 2022 Share Posted May 5, 2022 did any ground connections get re-connected with the VC cover r&r ? vacuum lines re-seated? along with what GD suggests, next time it's misfiring/stumbling at idel, squirt some starting fluid/brake cleaner in the intake. If it smooths-out, maybe that points to a fueling problem? is system voltage OK at idle? Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 5, 2022 Author Share Posted May 5, 2022 (edited) On 5/5/2022 at 3:22 PM, 1 Lucky Texan said: did any ground connections get re-connected with the VC cover r&r ? vacuum lines re-seated? along with what GD suggests, next time it's misfiring/stumbling at idel, squirt some starting fluid/brake cleaner in the intake. If it smooths-out, maybe that points to a fueling problem? is system voltage OK at idle? Expand i only pulled the stuff connected to the drivers side head. breather tube spark plug wires took the fill neck off removed battery and washer fluid tank. did not have to unhook any grounds or vacuum lines. voltage is good at battery. Edited May 5, 2022 by sirtokesalot Link to comment Share on other sites More sharing options...
heartless Posted May 6, 2022 Share Posted May 6, 2022 just gonna throw this out there... one of my Legacy's acted similarly & it turned out to be a bad O2 sensor.. it would start and idle fine, but get into the throttle and it would stumble and what seemed to be a misfire... took a long time for it to finally throw a code, tho Was about at my wits end with the damned thing when it finally got around to throwing the code. 2 Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 6, 2022 Author Share Posted May 6, 2022 On 5/6/2022 at 5:39 AM, heartless said: just gonna throw this out there... one of my Legacy's acted similarly & it turned out to be a bad O2 sensor.. it would start and idle fine, but get into the throttle and it would stumble and what seemed to be a misfire... took a long time for it to finally throw a code, tho Was about at my wits end with the damned thing when it finally got around to throwing the code. Expand so if it starts missing and acting up again would resetting the ecu and unplugging the front o2 sensor be a good test to see if the sensor is an issue? drive it with the o2 unplugged and if the symptom doesn't return with it unplugged then assume the o2 is bad? Link to comment Share on other sites More sharing options...
lmdew Posted May 7, 2022 Share Posted May 7, 2022 I beleve the ECU needa good O2 sensor Reading for proper opertion. Quote Quote Expand Expand Link to comment Share on other sites More sharing options...
heartless Posted May 7, 2022 Share Posted May 7, 2022 unplugging it would cause similar symptoms (and throw a code right away) - ecu does need proper o2 readings to make the right fuel/air ratio adjustments. now, here is the kicker... o2 only comes into play once things are fully warmed up.. cold engine runs on set values until it reaches operating temp, then o2 readings take over to make minute adjustments while driving. not saying that this is definitely your issue, just something else to think about/consider. hope you get it figured out soon Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 7, 2022 Author Share Posted May 7, 2022 On 5/7/2022 at 11:00 AM, heartless said: unplugging it would cause similar symptoms (and throw a code right away) - ecu does need proper o2 readings to make the right fuel/air ratio adjustments. now, here is the kicker... o2 only comes into play once things are fully warmed up.. cold engine runs on set values until it reaches operating temp, then o2 readings take over to make minute adjustments while driving. not saying that this is definitely your issue, just something else to think about/consider. hope you get it figured out soon Expand ah i had thoght with the o2 unplugged the car would just run at a default value in open loop. ill probly just buy an o2 sensor anyways seeing as its probly original. ive never changed it. Link to comment Share on other sites More sharing options...
heartless Posted May 7, 2022 Share Posted May 7, 2022 yeah, it would only run that way until it reached operating temp.. Link to comment Share on other sites More sharing options...
montana tom Posted May 7, 2022 Share Posted May 7, 2022 Don't buy a cheap one or you'll be relacing it again soon. O.E. or denso Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 7, 2022 Share Posted May 7, 2022 Actually the O2 comes online much sooner than operating temp. The sensor has it's own heating element and will be online and operating within about 2 minutes typically. GD 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 7, 2022 Share Posted May 7, 2022 Immediately (before 2-3 drive cycles) after a battery disconnect 'reset', the ECU uses the factory base map in firmware to run the car. If the car's symptoms get better after a reset, that may point to a bad signal from a sensor. If it doesn't get better, might something physical like a dropped valve guide or ??? Link to comment Share on other sites More sharing options...
sirtokesalot Posted May 9, 2022 Author Share Posted May 9, 2022 the car made it 1100 miles to and from my mas in vermont over the weekend issue did not return. Link to comment Share on other sites More sharing options...
