sirtokesalot Posted May 6, 2022 Share Posted May 6, 2022 this one is not as important being a yard car i plow with in the winter. over this past winter the wipers stopped working on low and intermittent only work on highest speed and will not park. they simply stop wherever they are when u shut the switch off. is there a common failure or somthing simple and cheap i could do to fix it? if its not a cheap oir free fix ill likely just deal with it seeing as the car is not ever going on the road again. Quote Link to comment Share on other sites More sharing options...
lmdew Posted May 7, 2022 Share Posted May 7, 2022 Sounds like the motor to me. Pretty easy to swap it out and see if that fixes it. Quote Link to comment Share on other sites More sharing options...
