palfer Posted May 7, 2022 Share Posted May 7, 2022 My 2009 (96K miles) automatic 4 EAT doesn't seem to what to make the shift from 3rd to 4th gear. Engine gets up to 4K rpm's and then it triggers the flashing AT Oil light, traction control, etc. I've checked the transmission fluid and the level is good. When I shut the car off and restart the flashing dash lights go away. Does this symptom ring a bell or any suggestions where to start troubleshooting? Thanks! Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 7, 2022 Share Posted May 7, 2022 just chiming in to confirm....fluid level checked while idling correct? id the car new to you? any recent wrecks or work done before this problem began? Link to comment Share on other sites More sharing options...
palfer Posted May 8, 2022 Author Share Posted May 8, 2022 yes, checked at idle and in neutral. I bought the car new. Link to comment Share on other sites More sharing options...
somick Posted May 9, 2022 Share Posted May 9, 2022 Was the fluid ever replaced? Good luck, Sam Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted May 9, 2022 Share Posted May 9, 2022 any dents in the trans pan? Link to comment Share on other sites More sharing options...
palfer Posted May 9, 2022 Author Share Posted May 9, 2022 Yes, I've changed fluid a few times. No damage to the pan. Link to comment Share on other sites More sharing options...
palfer Posted May 14, 2022 Author Share Posted May 14, 2022 Came on again yesterday after a 40 mile drive. It shifted just fine the whole ride. What causes that light to illuminate or could be a number of things? Link to comment Share on other sites More sharing options...
palfer Posted May 27, 2022 Author Share Posted May 27, 2022 Update on this. Light has not come back on but was driving at about 70mph and the transmission downshifted for no apparent reason. Went a few more miles then it upshifted to overdrive once again. I was able to pull a few codes using the headlight and trip odometer process. C0045 and C0071. Link to comment Share on other sites More sharing options...
