Hay all
Don't no if you have seen my build
Brumby with mid mount bg5 engine.
Just having a problem with the vss wiring.
So the engine and wiring is out of a 1996 bg5 gt legacy.
Now on the wiring harness has a plug for the vss.
Q: do I still use that plug and plug it in?
Also we have removed the TCU as prescribed and now are trying to wire that up.
But all I read is that you wire it to the vss? (confusing as it has that plug)
So I no we need a 5volt power source to run that vss,
So we nick a power wire, earth wire, signal wire from the tcu plugs.
But what now?
Do i need to wire them to vss or dash or?
The good news I have a ecu pinout for a 1997 gt legacy (thats helps alot) but no tcu pinout.
Pin for me are looking from the wire side.
All comments welcome
Thanks doc
