Daskuppler Posted August 29, 2022 Author Share Posted August 29, 2022 On 8/29/2022 at 12:52 AM, jonathan909 said: I can't begin to imagine why. Expand Okay. I didn't know how quickly they can slide of our flat. I know they say to always resurface when the heads come off, but that's expected after 100k miles. Link to comment Share on other sites More sharing options...
jonathan909 Posted August 29, 2022 Share Posted August 29, 2022 (edited) It's not magic. Deforming a big chunk of metal takes a combination of time, force, and heat. You didn't hit it, didn't overheat it, and there wasn't much time. And yeah, I know "they" say that, but (and I'm the first to admit how limited my experience is) I usually go with "if it ain't broke, don't fix it". If you can't prove that it's out of flat, why start milling? Subaru's book of words tells you what the flatness requirement is. So I get out my machinist's rule and feeler gauges, and if it meets spec it doesn't go out for a shave and a haircut. Edited August 29, 2022 by jonathan909 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 30, 2022 Share Posted August 30, 2022 If the cam journals aren't spanked from this many engine failures, and assuming they were resurfaced the first time they should be fine to just run through the parts washer and bolt up to a new block without any surfacing. Not enough miles or enough heat cycles to leave any significant fire ring damage, etc. GD Link to comment Share on other sites More sharing options...
Daskuppler Posted August 31, 2022 Author Share Posted August 31, 2022 (edited) On 8/30/2022 at 11:40 PM, GeneralDisorder said: If the cam journals aren't spanked from this many engine failures, and assuming they were resurfaced the first time they should be fine to just run through the parts washer and bolt up to a new block without any surfacing. Not enough miles or enough heat cycles to leave any significant fire ring damage, etc. GD Expand Okay. Thank you. It stopped putting power out to the wheels despite the engine reving so I suspect something worse has happened...then the red oil light and it turned itself off. We will see. Mother Subaru has not responded yet and the dealership is still "finding room to do the tear down". One more failed engine and it should fall under Lemon Law. Edited August 31, 2022 by Daskuppler Link to comment Share on other sites More sharing options...
Daskuppler Posted August 31, 2022 Author Share Posted August 31, 2022 On 8/29/2022 at 3:10 AM, jonathan909 said: It's not magic. Deforming a big chunk of metal takes a combination of time, force, and heat. You didn't hit it, didn't overheat it, and there wasn't much time. And yeah, I know "they" say that, but (and I'm the first to admit how limited my experience is) I usually go with "if it ain't broke, don't fix it". If you can't prove that it's out of flat, why start milling? Subaru's book of words tells you what the flatness requirement is. So I get out my machinist's rule and feeler gauges, and if it meets spec it doesn't go out for a shave and a haircut. Expand That makes sense. When I did the heads on my 02.impreza a few years ago, I learned the hard way to have them checked. Ended up blowing the head gasket in about 15k. This time it's not my rodeo though haha Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 1, 2022 Share Posted September 1, 2022 maybe an axle is not fully seated? Link to comment Share on other sites More sharing options...
Daskuppler Posted September 1, 2022 Author Share Posted September 1, 2022 On 9/1/2022 at 4:32 PM, 1 Lucky Texan said: maybe an axle is not fully seated? Expand No idea. I would lean more towards broken output shaft/crank shaft based on the amount of metal in the oil. Should have an answer in 6 weeks if their track record holds true. Whatever it is, it's warranty so that's at least a bonus... Link to comment Share on other sites More sharing options...
Daskuppler Posted September 25, 2022 Author Share Posted September 25, 2022 The official diagnosis for the second block is a #2 spun rod bearing and seized main bearings. The tech said he could spin the engine, but barely. Still waiting on instructions from SOA on how to proceed for the third block. I asked for a FB25D but they said no haha. Link to comment Share on other sites More sharing options...
