MWLoyale Posted August 20, 2022 Share Posted August 20, 2022 👍 Hello, time to get the loyale back up n running. I'm hoping to get this stinking gl instrument cluster to plug into my loyale and it's been fun swapping wires around... I have two last wires that need to be plugged in. I believe they are for a small ecu hidden within the cluster. I removed one of the motherboards and it revealed this small ecu that isn't in my loyale cluster. If anyone has any information on the wires coming out the back I would be lucky to see what you know. I will post pictures to hopefully clear up any confusion in the description. Link to comment Share on other sites More sharing options...
MWLoyale Posted August 20, 2022 Author Share Posted August 20, 2022 I could assume power and ground for it, but i don't know what it is. https://drive.google.com/file/d/1tBBDWB7U2EC3HZtCae9G-U6kaOM6VnTK/view?usp=drivesdk https://drive.google.com/file/d/1t5kvMrrv6CariUSNlJdxts0clGrRIsiM/view?us Link to comment Share on other sites More sharing options...
MWLoyale Posted August 20, 2022 Author Share Posted August 20, 2022 Just now, MWLoyale said: I could assume power and ground for it, but i don't know what it is. https://drive.google.com/file/d/1tBBDWB7U2EC3HZtCae9G-U6kaOM6VnTK/view?usp=drivesdk https://drive.google.com/file/d/1t5kvMrrv6CariUSNlJdxts0clGrRIsiM/view?us So I need to know where the blue wire goes and the pale green. Link to comment Share on other sites More sharing options...
MWLoyale Posted February 22, 2023 Author Share Posted February 22, 2023 Bump Link to comment Share on other sites More sharing options...
el_freddo Posted February 22, 2023 Share Posted February 22, 2023 Sorry mate, I’m all out of ideas. When I did this I swapped the entire vehicle loom in the process as I wanted to run the MPFI setup in my DL - and that was before I learned about the EJ conversion! All the best with it. Cheers Bennie Link to comment Share on other sites More sharing options...
