93 Loyale to GL gauge cluster
šŸ‘
Hello, time to get the loyale back up n running.
I'm hoping to get this stinking gl instrument cluster to plug into my loyale and it's been fun swapping wires around...
I have two last wires that need to be plugged in. I believe they are for a small ecu hidden within the cluster. I removed one of the motherboards and it revealed this small ecu that isn't in my loyale cluster. If anyone has any information on the wires coming out the back I would be lucky to see what you know.
I will post pictures to hopefully clear up any confusion in the description.
  On 8/20/2022 at 3:05 AM, MWLoyale said:
Expand
So I need to know where the blue wire goes and the pale green.
  • 6 months later...
Sorry mate, I’m all out of ideas. When I did this I swapped the entire vehicle loom in the process as I wanted to run the MPFI setup in my DL - and that was before I learned about the EJ conversion!
All the best with it.
Cheers
Bennie
Ɨ
Ɨ
