wtdash Posted August 26, 2022 Share Posted August 26, 2022 Hi, Picked up a '97 Legacy L Wagon for cheap to fix the engine. Has a 150K miles. It needs struts and I can buy cheap KYB's on Rockauto or Ebait for the OB, AND I'll be able to run a bigger tire (but just the stock-ish - 205/70R15 or 215/60R16). Will the Legacy Springs on the OB Struts provide any lift? Tangent: I put a 215/60r16 Forester spare on my Legacy and it clears the front and rear lower strut perch, but the back is close - both the top and inside of the tire. Also, I'd usually just buy the complete strut assemblies from the local PullNSave yard, but have had bad luck w/those as they all have a ton of miles. Link to comment Share on other sites More sharing options...
idosubaru Posted August 26, 2022 Share Posted August 26, 2022 I’ve installed legacy springs on outback struts. don’t recall what it did to the overall height as I didn’t install them on a legacy. I’d guess you get a 1” lift instead of 2”. 1 Link to comment Share on other sites More sharing options...
ferp420 Posted August 27, 2022 Share Posted August 27, 2022 (edited) the lego springs dont give any lift at all the outback strut has more traval than the lego strut and the spring is bigger the outback spring on a lego strut will be close to full exstension of the strut a lego spring on a outback strut will be at the bottom of the struts traval you would.bottom out alot like that the best lift was outback struts with forester springs but the differance was maybe a 1/2 " at most not worth the extra work or exspence the outback struts give the lego about 1 1/2" of lift a bit more on the impreza but not a true 2" lift note our 03 lego with 2" lift left the rear alignment out of specks we had to buy white racing adjustable rear links to keep the rear from eating tires not a big deal you could also use the drop brackets from the outback to keep the rear alignment in specks xt springs are stiffer than standerd outback springs and the 6 cylinder springs should be stiffer than those Edited August 27, 2022 by ferp420 1 Link to comment Share on other sites More sharing options...
Numbchux Posted March 13, 2024 Share Posted March 13, 2024 Nobody click the links in the post above! New member, edited post. Sketchy AF 1 Link to comment Share on other sites More sharing options...
