torpedo51 Posted August 31, 2022 Share Posted August 31, 2022 (edited) I know that the gasket set may be used for multiple variations, and I may not end up using all of these. I don't want to miss one of these during the assembly stage of my project. I removed the "easy ones" from the picture. A - NOT thermostat (smaller than the included thermostat gasket) B - turbo equipment C - EGR D E F - turbo equipment G - turbo equipment H J K - case plugs? L - case plus for wrist pins? Slightly too big to fit into recessed bore on case! M - compression washer - for what? N O P Q R S - turbo equipment Edited August 8 by torpedo51 Added some info 1 Link to comment Share on other sites More sharing options...
Steptoe's photos Posted September 2, 2022 Share Posted September 2, 2022 F and S are turbo mounting and exit gasketsso either file away or get a turbo. A is thermostat from the looks.C will fit some EGR units Link to comment Share on other sites More sharing options...
