i need a throttle position sensor for my 1991 subaru Loyale
Read your codes from the ECU. Decipher them from the list. Go from there.
Sounds to me more like one of the following:
- bad or dirty AFM
- dead O2 sensor
- bad/dead coolant temp sensor
Don’t go throwing money at it until you know what the codes are ;)
Cheers
Bennie
  • Like 1
My lazy method would be to renew O2 sensor first, or more effort would be to decipher which incoming wire at ECU is O2 sensor and measure it's input from cold start to warm and throttle blips. Poor condition injectors if you have mpfi or I bet you have spfi ??
First step would be to disconnect O2 sensor and see what difference you get and share result of the most simplest diagnostic step
Edited by Steptoe's photos
