211 Posted September 20, 2022 Share Posted September 20, 2022 I have a 2000 OBW with a JDM 2.0 engine transplant. I'm having a hard time finding HG's specific to the 2.0. Title says it all. Are the 2.5 SOHC non-turbo HG's compatible? Link to comment Share on other sites More sharing options...
el_freddo Posted September 20, 2022 Share Posted September 20, 2022 No. They will physically fit and bolt in but the firing ring in the head gasket will be in the ring spot and could cause issues. @GeneralDisorderwill know more about the complications of this. Why not get head gaskets for the EJ20 that you have? Cheers Bennie Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 20, 2022 Share Posted September 20, 2022 GD has mentioned before that it is difficult to get 2.0 parts. Link to comment Share on other sites More sharing options...
211 Posted September 20, 2022 Author Share Posted September 20, 2022 On 9/20/2022 at 7:35 PM, 1 Lucky Texan said: GD has mentioned before that it is difficult to get 2.0 parts. Expand This^^ Having a hard time sourcing quality HG's specific to the EJ20 Link to comment Share on other sites More sharing options...
Numbchux Posted September 21, 2022 Share Posted September 21, 2022 WRX 2.0 head gasket should work just fine. Everything else is the same as SOHC 2.5. Very easy to get parts with that little bit of information. 1 Link to comment Share on other sites More sharing options...
211 Posted September 21, 2022 Author Share Posted September 21, 2022 (edited) Holding up an EJ25 gasket to the block of a EJ20, the bore on the 2.0 is much smaller. We thought about EJ20 turbo HG's but those are thicker and would likely change the timing a little bit. I'll look into the WRX 2.0 gaskets thanks Edited September 21, 2022 by 211 Link to comment Share on other sites More sharing options...
el_freddo Posted September 21, 2022 Share Posted September 21, 2022 The thickness of the head gaskets needs to be quite significant to really effect the cam timing so much that you’ll experience a difference or lose power etc. What I could effect is the compression ratio, but again, this would t be noticeable nor effect the ECU’s engine management. There are plenty of places to buy EJ20 gaskets. Australia has a big market of EJ20 engines and thus the HGs are readily available. Postage is the real issue here. There will be other places across the globe that would be easier to source. As numbchux said, the EJ20 turbo gaskets will do the job just fine. Cheers Bennie Link to comment Share on other sites More sharing options...
Numbchux Posted September 21, 2022 Share Posted September 21, 2022 I know STi turbo head gaskets are used on the SOHC 2.5 all the time, I would think WRX would be the same. Timing change would be negligible, compression might be noticeable. Link to comment Share on other sites More sharing options...
Numbchux Posted September 21, 2022 Share Posted September 21, 2022 http://opposedforces.com/parts/info/11044AA483/ https://www.ebay.com/itm/192453951693 both list SOHC non turbo and turbo 2.0 applications. That's what I would use. USDM source, lists WRX EJ205 https://www.subarupartsdeal.com/parts/subaru-gasket-cylinder-head~11044aa483.html Link to comment Share on other sites More sharing options...
nvu Posted September 21, 2022 Share Posted September 21, 2022 On 9/21/2022 at 3:01 PM, 211 said: Holding up an EJ25 gasket to the block of a EJ20, the bore on the 2.0 is much smaller. We thought about EJ20 turbo HG's but those are thicker and would likely change the timing a little bit. I'll look into the WRX 2.0 gaskets thanks Expand The old 90's EJ20K turbo used thicker gaskets. The ones numbchux pointed out are the thin MLS ones that should work. When in doubt, measure the old gaskets. Link to comment Share on other sites More sharing options...
