8Ball Posted November 18, 2022 Share Posted November 18, 2022 87 DL Sedan Blowing fuse upon turn of the key to start position, I don`t have the fuse cover to see what this fuse is for but must have something to do with starting system. I rebuilt the engine and pulled the coil wire and grounded it to pump up oil pressure and it cranked just fine to get pressure up, but this problem showed up after putting coil wire back together This coil has the transiter on it could i have burnt that up while cranking for the oil pressure test? Fuse location is middle row third from right facing fuse bank (15 amp) Thanks for any help you can give maybe picture of back side of cover for the fuse information. Link to comment Share on other sites More sharing options...
Ionstorm66 Posted November 19, 2022 Share Posted November 19, 2022 Could be the coil fuse. Link to comment Share on other sites More sharing options...
8Ball Posted November 19, 2022 Author Share Posted November 19, 2022 Thanks very helpful. Link to comment Share on other sites More sharing options...
