Sos Ea81 3rd Stuck
Rick, funny how the 4 speed trannies all seem to do the same thing. Another one of our cars had the exact same symptom. We learned to take it out of 4th before coming to a stop; otherwise it would get stuck.
I've put an EA81 FWD 5 speed into a 4WD body - it goes right in. There's no clearance issues like going the other way, and the stud for the shifter assembly is already present. No problem at all. It will even work with the same clutch, as the splines are the same too. You can just leave the rear end - just unbolt the driveshaft from the diff.
