idosubaru Posted December 26, 2022 Share Posted December 26, 2022 (edited) Why is the brake light flashing with check engine light, but nothing else is on? 2014 H4 OB If it’s brake related the traction, ABS and cruise lights would light up. But this isn’t doing that. There's a TSB for the parking brake actuator failure. Though it doesn't mention if the check engine light comes on: https://static.nhtsa.gov/odi/tsbs/2019/MC-10162997-9999.pdf Gas cap and oring is fine. I’m going to operate the parking brake a few times, check the coolant level. I’m traveling for holiday and not my car so I’ll drive it later to read codes at store. Edited December 26, 2022 by idosubaru Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted December 26, 2022 Share Posted December 26, 2022 seems weird but I know little about the newer cars - probably check brake fluid too I guess. You could try a battery disconnect reset...... 1 Link to comment Share on other sites More sharing options...
forester2002s Posted December 26, 2022 Share Posted December 26, 2022 On 12/26/2022 at 8:35 PM, 1 Lucky Texan said: check brake fluid Expand +1 Link to comment Share on other sites More sharing options...
Ferret54 Posted December 26, 2022 Share Posted December 26, 2022 Also check for 14.2 volts at battery with engine running .... Could be alternator diode(s0 gone bad. 1 Link to comment Share on other sites More sharing options...
Daskuppler Posted December 27, 2022 Share Posted December 27, 2022 The brake light flashed in my 14 Forester when brake fluid was low. I don't recall the cel being in though. Any codes? Link to comment Share on other sites More sharing options...
idosubaru Posted December 27, 2022 Author Share Posted December 27, 2022 On 12/27/2022 at 12:04 PM, Daskuppler said: The brake light flashed in my 14 Forester when brake fluid was low. I don't recall the cel being in though. Any codes? Expand P0171 Bank one system lean. A vacuum hose issue might cause brake issue and system lean? I'll check brake booster? On 12/26/2022 at 8:35 PM, 1 Lucky Texan said: seems weird but I know little about the newer cars - probably check brake fluid too I guess. You could try a battery disconnect reset...... Expand Right on, didn't cross my mind. It is full. Today he said the parking brake didn't work. I found a TSB for 2010-2014 unlimited mileage 15 year extended warranty on the automatic parking break module. TSB 06-71-19R https://static.nhtsa.gov/odi/tsbs/2019/MC-10166898-0001.pdf 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 28, 2022 Share Posted December 28, 2022 Yeah the parking brake modules are basically guaranteed forever on those things. On some models my guy at Subaru says the warranty is unlimited mileage, and 99 years. Apparently it's enough of a safety issue that they will be fixing these essentially forever. GD 1 1 Link to comment Share on other sites More sharing options...
