mellow65 Posted February 13, 2023 Share Posted February 13, 2023 I have a question about some injectors I pulled from a parts engine, it was a 96-97 legacy 2.2 and they came with grey top injectors. All my searching tells me there were really early grey tops, then red tops for a long time, but no one really talks about the later grey tops. It looks like they were standard issue in the early 1.8 and 2.2 imprezas. Does anyone have any information about these? Mainly flow rates. I'm looking to replace some red top injectors in my 94, and the fact the later grey tops are almost half the cost of the red tops new, makes me wonder what the specs are on them. I'm trying to avoid ending up with something with a lower fuel rate, and I can not find any real information about these injectors. I did at least see some people running the grey tops in place of the red tops, so I do at least know it's possible. THANKS!!! Link to comment Share on other sites More sharing options...
wtdash Posted February 14, 2023 Share Posted February 14, 2023 Not much to add, except GD doesn't like the grey injectors - as they're less reliable than reds, IIRC. I have two IM's hanging in the garage and one with greys and one with reds - both from mid-90s EJ22s. Link to comment Share on other sites More sharing options...
el_freddo Posted February 14, 2023 Share Posted February 14, 2023 I think the greys were found on the autos and the reds found on the manual engines - possibly only for the series 1 setup as the red to injectors are very common from my understanding. With the engine management on these vehicles I highly doubt they’re that highly calibrated/sensitive to an injector swap like this. Just do an ecu reset between the swap and let it relearn its settings before driving it. Or just get the red ones, you could have them cleaned and flow tested if you felt the need to on the old ones. Cheers Bennie Link to comment Share on other sites More sharing options...
mellow65 Posted February 22, 2023 Author Share Posted February 22, 2023 These aren't from the early legacys, these came out of a 97 single port phase 1 ej22. But yeah I'm still coming up with no good information about these specifically. I'll just go hit the junk yard and grab a spare set. Thanks!! Link to comment Share on other sites More sharing options...
lmdew Posted February 23, 2023 Share Posted February 23, 2023 I have lot of reds. You pay shipping. Larry 1 Link to comment Share on other sites More sharing options...
