573417h Posted February 28, 2023 Share Posted February 28, 2023 Hi Team, As per above, just researching this topic a bit and am wondering if there are any physical difference in regard to mounts, shifter location etc, i have googled + image search to try and work it out but not getting much in a direct comparision. I suspect there will be a size difference but want to confirm. Thanks Quote Link to comment Share on other sites More sharing options...
Numbchux Posted February 28, 2023 Share Posted February 28, 2023 (edited) Assuming you are talking about the older strong STi 6-speed, no, it's much larger. Requires a shorter driveshaft and shift linkage. I think the mount is in the same place, but I could be wrong... I don't know about the newer split case 6-speeds, they're not nearly as strong, so likely not as physically large as the STi ones. Edited February 28, 2023 by Numbchux 2 Quote Link to comment Share on other sites More sharing options...
