2006 Forester water in headlights repair?
  • 2 weeks later...
Yeah, the last time I had a similar Issue was on a '91 Loyale with glass lenses. The fix? Bake the lens at 300F for an hour and silicone the holes shut.
Probably not applicable in your case and it's honestly easier to just replace the plastic lenses for way less hassle.
As far as I understand it takes a LOT of patience and time to separate the composite lens to get it cleaned up and eventually re seal things. You may get lucky and upon inspection find a tiny hole that can be glued shut?
Usually though it's small imperfections In the lens adhesive or bulb gaskets that lets the condensation in.
An easy trick would be to drill some small holes in the bottom of the lens to equalize it to the atmosphere and reduce the possibility of condensation, but overall the few bolts you need to remove to replace the light is probably the best permanent solution...
