l75eya Posted March 30, 2023 Share Posted March 30, 2023 I struggled with this damn torque converter in this 94 legacy for like an hour. It still doesn't seem fully seated to me (i have the starter bolted up and if I pull the starter gear all the way out, it doesn't reach the ring gear on the torque converter. Also, I can get my fingers behind the torque converter). I can get it to slide in once, then twice, and that's it. It seems like it should have one more groove to fall into. Link to comment Share on other sites More sharing options...
ocei77 Posted March 30, 2023 Share Posted March 30, 2023 Lift it as you turn and apply inward pressure. When fully seated it should be out about 1/4 inch from the housing. O. Link to comment Share on other sites More sharing options...
l75eya Posted March 30, 2023 Author Share Posted March 30, 2023 So getting my fingers between the transmission casing and the back of the torque converter and the starter gear not reaching is definitely a sign of it not being fully seated, yes? Link to comment Share on other sites More sharing options...
idosubaru Posted March 30, 2023 Share Posted March 30, 2023 Starter can be an indicator if it’s working properly and you’re testing when extended as if starting and not just statically putting jt there. The solenoid pushes it out further. When the engine and trans are bolted together the flex plate and fully seated converter ***will not touch***. There’s a gap and the TC bolts draw the TC and flex plate together. Measure the TC distance to trans bell housing and flex plate distance to engine side bell housing. it’ll be obvious the engine side measurements can’t show interference with the trans side measurements. If the flex plate is recessed inside the engine bellhousing 1/2” then the TC can’t protrude more than 1/2” out of the trans bellhousing. If the mating surface on the TC sticks out 3/4” past the trans bell housing then you know it’ll interfere with the engine. Those are made up numbers for reference. Link to comment Share on other sites More sharing options...
l75eya Posted March 30, 2023 Author Share Posted March 30, 2023 26 minutes ago, idosubaru said: Starter can be an indicator if it’s working properly and you’re testing when extended as if starting and not just statically putting jt there. The solenoid pushes it out further. When the engine and trans are bolted together the flex plate and fully seated converter ***will not touch***. There’s a gap and the TC bolts draw the TC and flex plate together. Measure the TC distance to trans bell housing and flex plate distance to engine side bell housing. it’ll be obvious the engine side measurements can’t show interference with the trans side measurements. If the flex plate is recessed inside the engine bellhousing 1/2” then the TC can’t protrude more than 1/2” out of the trans bellhousing. If the mating surface on the TC sticks out 3/4” past the trans bell housing then you know it’ll interfere with the engine. Those are made up numbers for reference. Yeah I was pulling the starter engagement gear all the way out on it's travel and it wasnt reaching. I'm trying to avoid dropping the engine in and having to take it out yet again. I want to make certain the torque converter is fully seated before I drop it in again. I have seated many TC in my day. I have never dealt with this before. Think this is only the second automatic Subaru I've worked on though. Link to comment Share on other sites More sharing options...
lmdew Posted March 30, 2023 Share Posted March 30, 2023 Quote They can be a bear. There is like 3 steps to fully seated. As stated above, if it's properly seated the flex plate bolts will pull the TC FWD about a 1/8" or so when tightened. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 31, 2023 Share Posted March 31, 2023 3 steps till seated. GD 1 Link to comment Share on other sites More sharing options...
idosubaru Posted March 31, 2023 Share Posted March 31, 2023 11 hours ago, l75eya said: I want to make certain the torque converter is fully seated before I drop it in again. Totally get it weve all been there. For certainty measure it like I described. Then it’s real easy to visually see/check/confirm that bell housing difference. 1 Link to comment Share on other sites More sharing options...
Numbchux Posted March 31, 2023 Share Posted March 31, 2023 3 sets of splines. But if you're not sure, measure. 1 Link to comment Share on other sites More sharing options...
l75eya Posted April 1, 2023 Author Share Posted April 1, 2023 Thank you all. Every TC I've ever seated had been 3 steps and I appreciate the confirmation it's the same here. Good to see you GD! Link to comment Share on other sites More sharing options...
l75eya Posted April 5, 2023 Author Share Posted April 5, 2023 Got it seated. Turns out the smaller diameter shaft sticking out of the transmission of the two in one style input shaft was the problem. It itself wasn't seated properly and was preventing everything from being recessed the way it was all supposed to be. Thanks for all the kind words all. 1 Link to comment Share on other sites More sharing options...
