wtdash Posted April 1, 2023 Share Posted April 1, 2023 2003 Legacy - wagon - 150K miles. Front Passenger electric window originally worked but would go up too far. Eventually stopped working altogether - from both the driver's master and passenger side switch. Replaced the window's regulator and motor and still not working. DOES work with 12v direct to motor. Switch is GOOD - works w/the rear window and the rear switch does not work on the passenger either. Assuming it must be the harness, but is there a common failure point? Maybe the harness under the boot / cover that runs between the door and body? Haven't checked that yet. Thanks for any feedback! Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 1, 2023 Share Posted April 1, 2023 Id still guess it’s the switch. Test it. Wet due to window being off track? 1 Quote Link to comment Share on other sites More sharing options...
lmdew Posted April 1, 2023 Share Posted April 1, 2023 In the flex section of the wiring frame to door. Check voltage at the motor under load! 1 Quote Link to comment Share on other sites More sharing options...
forester2002s Posted April 2, 2023 Share Posted April 2, 2023 Blown fuse? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 2, 2023 Share Posted April 2, 2023 3 hours ago, lmdew said: In the flex section of the wiring frame to door. Check voltage at the motor under load! Oh heck yeah. If it’s wiring it’s almost always inside that flex boot conduit. Quote Link to comment Share on other sites More sharing options...
