opus Posted June 16, 2023 Share Posted June 16, 2023 I have a good driver but it has piston slap. Belt apparently broke. Do I bother putting rebuilt heads on it since it has slap? Link to comment Share on other sites More sharing options...
lmdew Posted June 16, 2023 Share Posted June 16, 2023 What's the mileage? Piston slap is not a huge problem. Does it go away when up to temp? I'm sure GD has more info for you. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted June 16, 2023 Share Posted June 16, 2023 (edited) 51 minutes ago, opus said: I have a good driver but it has piston slap. Belt apparently broke. Do I bother putting rebuilt heads on it since it has slap? Piston slap can be fixed with the heads off with new pistons or if you have a shop that will knurl the pistons for you. With heads off, unscrew the piston pin access hole, pop the pins out and the pistons come up through the bore where the heads were. What larry said. I wouldn't worry about normal piston slap. And I'd wonder if it was reasonably maintained, and how much oil it was consuming. Edited June 16, 2023 by idosubaru Link to comment Share on other sites More sharing options...
opus Posted June 16, 2023 Author Share Posted June 16, 2023 No oil consumption or leaks. 200k 2nd owner, very well maintained. It goes away 90% but pretty quiet warmed up.. Link to comment Share on other sites More sharing options...
lmdew Posted June 16, 2023 Share Posted June 16, 2023 Drive it. 1 Link to comment Share on other sites More sharing options...
opus Posted June 17, 2023 Author Share Posted June 17, 2023 I'm having no luck finding heads without getting borked. Where's a good place for valves, seats, guides? Link to comment Share on other sites More sharing options...
lmdew Posted June 17, 2023 Share Posted June 17, 2023 (edited) www.car-part.com is worth a shot for heads. Edited June 17, 2023 by lmdew Link to comment Share on other sites More sharing options...
Numbchux Posted June 17, 2023 Share Posted June 17, 2023 Are you asking about replacing heads because the belt broke? If so, just have a machine shop replace the bent valves. The heads are fine. Link to comment Share on other sites More sharing options...
idosubaru Posted June 17, 2023 Share Posted June 17, 2023 17 hours ago, opus said: I'm having no luck finding heads without getting borked. Where's a good place for valves, seats, guides? Ask your local Subaru service department where they get their machine shop work done. The ones I know mostly avoid machine shop work entirely but they still always have a job or 5 they need something done for by a machine shop. Link to comment Share on other sites More sharing options...
opus Posted June 18, 2023 Author Share Posted June 18, 2023 I found heads. Everything for me has to be online. Any machine shop, parts yard, etc is 150+ miles away. Link to comment Share on other sites More sharing options...
