bork Posted June 21, 2023 Share Posted June 21, 2023 Looking to do a flush out since I got this car approx 2 years ago with only 52k miles on it. Do I refill with green prestone or special Sub blue stuff? Any supplemental additives need added? Link to comment Share on other sites More sharing options...
lmdew Posted June 22, 2023 Share Posted June 22, 2023 Green is fine. Link to comment Share on other sites More sharing options...
nvu Posted June 23, 2023 Share Posted June 23, 2023 For a '96, it probably needs a new upper radiator hose. Squeeze the hose with your hand, if you hear crunchy sounds it's time for a replacement. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 23, 2023 Share Posted June 23, 2023 Green if you want no problems. Blue if you want a clogged heater core and more rapid deterioration of cooling system plastics. GD Link to comment Share on other sites More sharing options...
bork Posted July 6, 2023 Author Share Posted July 6, 2023 Thank you all ! Funny I did squeeze the upper hose an heard a crunch & thought maybe there's an old rusty spring in there. I think I best change them both & be done with it. Should I go OE Subaru or aftermarket? Link to comment Share on other sites More sharing options...
heartless Posted July 6, 2023 Share Posted July 6, 2023 OE for easy fitment, aftermarket if you want fitting hassles - having to trim, bends arent quite right, etc... Link to comment Share on other sites More sharing options...
idosubaru Posted July 13, 2023 Share Posted July 13, 2023 On 7/5/2023 at 9:34 PM, bork said: Thank you all ! Funny I did squeeze the upper hose an heard a crunch & thought maybe there's an old rusty spring in there. I think I best change them both & be done with it. Should I go OE Subaru or aftermarket? The OEM hoses are absolutely notable better quality (stiff/firm/cut different) fit, last longer, and you'll be sure to get the right hose. Not worth saving $10 unless the car is a rust heap nearing it's death. The lower hose and clamps typically contact road debris/chemicals/winter treatments more than the top and are worth checking closely. Link to comment Share on other sites More sharing options...
nvu Posted July 13, 2023 Share Posted July 13, 2023 The radiator endtank is plastic, gets brittle and cracks easily, even when leaning over the engine bay and you inadvertently put your weight on it. The hose is likely fused to the nipple, cut it and peel away if needed. Also don't go overboard tightening the hose clamp on the radiator end. 1 Link to comment Share on other sites More sharing options...
