old sub freak Posted July 20, 2004 Share Posted July 20, 2004 on my friends 84 brat[ea81] had heads milled. now to adjust non adjustable valves. its been years since i did this, tighten all the way down, set 15 min., tighten till contact and 1/2 turn tighter? right?? any info would be cool .thanks todd ,see you at hood river Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2004 Share Posted July 20, 2004 on my friends 84 brat[ea81] had heads milled. now to adjust non adjustable valves. its been years since i did this, tighten all the way down, set 15 min., tighten till contact and 1/2 turn tighter? right?? any info would be cool .thanks todd ,see you at hood riverYeah - that's a tough procedure to find - the generic manuals don't cover it. Here it is from one of my FSM's (complete with crappy japanese translation ): (Note that you do this to the valves when they are in the slack position, with the cylinder you are adjusting at TDC on the compression stroke.... [and you don't need the silly tool - 6" crescent wrench works just fine]) a. Raise up the bend of the lock washer, loosen the lock nut, and then turn the valve rocker screw clockwise by approx. four (4) turns using Valve Clearance Adjuster 498767000. b. Leave it with the valves opened for approx 15 minutes. c. Unscrew the valve rocker screw gradually. Then, the rocker arm stops moving due to the closing of the valve. This condition is called "Zero Point". d. Moreover, unscrew the valve rocker screw counterclockwise by another 1.5 turns. e. Tighten the lock nut and bend the lock washer. GD Link to comment Share on other sites More sharing options...
old sub freak Posted July 20, 2004 Author Share Posted July 20, 2004 hey general, thanks for the info. i was close but no cigar. take care, todd Link to comment Share on other sites More sharing options...
