lmdew Posted July 20, 2004 Share Posted July 20, 2004 I picked up a 92 2WD Loyale wagon with a bad Auto Trans. I can push it forward in neutral, but only a foot or two in reverse and it locks up. Also the starter will not turn the engine, but I can rotate it through by had with normal resistance. I think I could unbolt the torque converter and that should free the engine from the trans, but I could still start the motor. Will it work? I want to check out the engine prior to doing the auto to manual trans swap. Ideas? Thanks Larry Link to comment Share on other sites More sharing options...
