[HTi]Johnson Posted July 20, 2004 Share Posted July 20, 2004 Yeah, it clicks when I turn right, slowly, and not giving it gas. It clicks from the driver's side. Could it be the shaft? I just put it in there not even a month ago. Oh and I know the brakes need replacing and the rotors turned/replaced. Could it be just the brakes? I haven't had time to look. Link to comment Share on other sites More sharing options...
subGSR Posted July 20, 2004 Share Posted July 20, 2004 Sounds like either a internal or external CV joint. hti-johnson said: Yeah, it clicks when I turn right, slowly, and not giving it gas. It clicks from the driver's side. Could it be the shaft? I just put it in there not even a month ago. Oh and I know the brakes need replacing and the rotors turned/replaced. Could it be just the brakes? I haven't had time to look. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2004 Share Posted July 20, 2004 Remaned CV's suck - I've even heard of ones that were shipped without any grease..... GD Link to comment Share on other sites More sharing options...
Bill90Loyale Posted July 20, 2004 Share Posted July 20, 2004 hti-johnson said: Yeah, it clicks when I turn right, slowly, and not giving it gas. It clicks from the driver's side. Could it be the shaft? I just put it in there not even a month ago. Oh and I know the brakes need replacing and the rotors turned/replaced. Could it be just the brakes? I haven't had time to look. Try jacking it up on the "click" side, and spinning the wheel. Could just be a rusted piece of the splash guard on the inboard side of the brake drum making contact and creating noise in turns. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2004 Share Posted July 20, 2004 Bill90Loyale said: Try jacking it up on the "click" side, and spinning the wheel. Could just be a rusted piece of the splash guard on the inboard side of the brake drum making contact and creating noise in turns. What is this "rust" you speak of? In Oregon, we have nothing like this.... GD Link to comment Share on other sites More sharing options...
All_talk Posted July 20, 2004 Share Posted July 20, 2004 Check the spindle/axel nut, I've had a loose one make such a noise and since you had it apart recently its even more likely. Gary Link to comment Share on other sites More sharing options...
Bill90Loyale Posted July 20, 2004 Share Posted July 20, 2004 GeneralDisorder said: What is this "rust" you speak of? In Oregon, we have nothing like this.... GD Rick- Count your blessings. The splash guard behind the rear drums, and of course the rocker panels etc just go to hell with the salt on the winter roads here. I have my car "hot oiled" once a year. They probably don't allow this in Oregon, but here, the first time you go, the guy literally drills holes in all the doors and rear gate compartments, sprays inside with hot oil, and puts plastic plugs in the holes till you bring the car back for another treatment. With this, and the decent new paint job that the Vo-Tech boys did and my fourteen year old looks very good. But those splash guards can begin to mimic failed wheel bearings. When this happened to me recently, I checked the torque on my axel nut (which was basically fine) and then found that it was that rusted splash guard. Pull the rubbing section off, and noise gone. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2004 Share Posted July 20, 2004 Bill90Loyale said: Rick-Count your blessings. The splash guard behind the rear drums, and of course the rocker panels etc just go to hell with the salt on the winter roads here. I have my car "hot oiled" once a year. They probably don't allow this in Oregon, but here, the first time you go, the guy literally drills holes in all the doors and rear gate compartments, sprays inside with hot oil, and puts plastic plugs in the holes till you bring the car back for another treatment. With this, and the decent new paint job that the Vo-Tech boys did and my fourteen year old looks very good. But those splash guards can begin to mimic failed wheel bearings. When this happened to me recently, I checked the torque on my axel nut (which was basically fine) and then found that it was that rusted splash guard. Pull the rubbing section off, and noise gone. Wow - that is replete with the suckage. I totally believe you that it can happen tho. My friends 98 Audi came from Wisconsin - the rust was something else. We took the lug bolts (yes - bolts - it's a VW thing I guess) off and the wheel was rusted on. We had to drive down the street with the bolts loose and slam the brakes on a couple times to dislodge them. GD Link to comment Share on other sites More sharing options...
Partsman Posted July 21, 2004 Share Posted July 21, 2004 hti-johnson said: Yeah, it clicks when I turn right, slowly, and not giving it gas. It clicks from the driver's side. Could it be the shaft? I just put it in there not even a month ago. Oh and I know the brakes need replacing and the rotors turned/replaced. Could it be just the brakes? I haven't had time to look. My experience with clicking involved replacement of the CV shaft (the obvious choice), then finding that the outer wheel bearing was rusting. Was afraid of the pressing of bearings, so I got a lo-miles spindle from B & R Pick & Pull, packed the bearings, replaced the seals and slapped it on. Voila! No noise! Link to comment Share on other sites More sharing options...
BobMadison2004 Posted July 27, 2004 Share Posted July 27, 2004 My front-end clicks when turning either direction. Oddly enough I had the CVs and boots replaced about three years ago so I doubt those are the culprits. The bearings are an interesting theory. The disk pads are fine too. So, sounds like my Loyale is about typical with these unexplained front-end noises. Link to comment Share on other sites More sharing options...
SubaSkeet Posted July 27, 2004 Share Posted July 27, 2004 argh! too many problems with the car! must destroy by driving off ledge and collecting insurance money! maybe that'll fix my supposed cv joint problem... Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted July 28, 2004 Author Share Posted July 28, 2004 Check the axle nuts, that was my culprit. Oh yeah, I fixed it. Link to comment Share on other sites More sharing options...
