Dr. RX Posted July 21, 2004 Share Posted July 21, 2004 Bummer I can't find my tool to confirm this, but I believe the tool needed to remove the stub axles from the rear diffs is this one from Snap-on, http://buy1.snapon.com/catalog/pro_det.asp?P65=&tool=all&item_ID=14957&group_ID=2358&store=snapon-store&dir=catalog , is this the correct tool??? Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 21, 2004 Share Posted July 21, 2004 That should be the one, I don't know if it is deep enough. If you can find one that is 1/4" drive, it will work better as it's small enough to get down inside the axle stub. I used an 8 point 8mm 1/4" drive deep well craftsman socket last time I had to pull stubs, you just have to be careful not to round it off! Link to comment Share on other sites More sharing options...
Qman Posted July 21, 2004 Share Posted July 21, 2004 Yes, that is it. Most tool truck sellers refer to these as air bag sockets. Link to comment Share on other sites More sharing options...
chef_tim Posted July 21, 2004 Share Posted July 21, 2004 From memory that sounds very correct. I'd go and look at mine but it's dark out and I'd never find it in the bottem of the tool pit. Later, Tim Link to comment Share on other sites More sharing options...
Craven Posted July 21, 2004 Share Posted July 21, 2004 I found one from SK 1/4" Dr Deep Female E10 TORX Socket pn #44960 $11.25 and Matco 1/4 X E10 RECESS TORX SOCKET Part#: A8XRA Price: $8.25 Link to comment Share on other sites More sharing options...
