Blowing white smoke
I was running around medford this evening and my car started billowing white smoke. It still runs ok and I even got home to ashland, It didnt get hot until I got off the freeway and dropped my friend off.
IM thinking i can fix it this weekend, but, I have no ride till then, which sucks.
I think i blew a headgasket, but Im hoping its somethign easier. and of course I dont know which one.
Alex
if neither the oil or the antifreeze has the other in it, yo might have a cracked head which means you can drive around for awhile like that:D I did it in an 86 turbosedan and it lasted a few months before the head cracked wide open and like a river, flooded into the exhaust:-\
well some moron didnt put the radiator cap back on after filling the water up after noticing the smoke last night in medford. So no wonder it got really hot (about 2mm below the pull over or die line). :rolleyes:
I filled the water up today after work (PS, the bus sucks), Checked the oil. No water in the oil, and no oil in the water. I got in and it started right up, no weird idle or any other signs of a massive failure. Also, it isnt blowing any more smoke( steam?). :banana:
IM going to take it to work with me tomorrow and see what happens.
Alex
Just a thought, but isn't your rig an automatic?? If the diaphram broke and it's now sucking huge amounts of ATF into the intake, it will blow billowing white smoke.
So I guess the question is, do you have a bit of steam coming out the rear, or are you pumping out clouds?
