freeldr Posted July 21, 2004 Share Posted July 21, 2004 i primarly worked on chevys and into subarus now. i recently put my soob together from misc parts basically its an ea81 carbed, and for the longest time i couldn't getit to run very well, i finally started fiddling with everything and the time and got it to idel about 800rmps, PASS EMISSIONS(missing half the egr crap, with major exhaust leaks), and run half decent, did evrything basically by ear and feel and finally today i took a timing light to it and it looks and if its running about 12 degrees BTDC, is that good? im used to advancing or retarding timing to tdc never past it. maybe some help is needed here.... Quote Link to comment Share on other sites More sharing options...
MilesFox Posted July 21, 2004 Share Posted July 21, 2004 for a carb motor 8 deg is stock. 12 is not far off, some like to bump the timing for performance. mine is past stock but i cant tell you what it is till i get a timing light fuel injected models are 20 deg, and 85-86 turbos are 25 Quote Link to comment Share on other sites More sharing options...
